- Nov 9, 2009
Just remember to cut with the sharp side.This thread is making me paranoid about using my Endura - the only lockback in my current arsenal.
I guess I don't really see the point of having such a beefy lock. If you're using your knife to cut something the way you're supposed to a lock isn't even necessary, which is why a lot of people, myself included, still use slipjoints.
'Normal' knife use doesn't exist, or if it does it ranges widely from sitting in a glass display to serving as a rung in a ladder and worse. 'Normal' is what everybody makes of it. I'm sure your idea of normal differs greatly from mine, and neither of us is wrong.I agree with previous posters that the Spartan is not comfortable at all to close.
While the lock may be somewhat stronger because of the pin that dilutes force, I don't think that for normal knife use, a classic well-designed back lock such as those made by Spyderco will be significantly less safe. Perhaps on a very long term.
There is no way to make a backlock that stays tight over a long period of intensive use. I own a Kershaw 1050 and it's one of the sstrongest heaviest thickest backlocks I've ever held. Pohl is the only one I know of that makes a thicker one. Closing a simple backlock with force, any upwards force on the edge (cutting but certainly a chopping-like action) will exert force on what is in effect both stoppin and pivot. It's a recipe for bladeplay.Now I am not a knife maker, but I have the suspicion that an interesting effect of the Triad lock is that the knife can be made with somewhat larger tolerances as the stop pin dilutes the force, a classic lock back on the other hand must be perfectly aligned to the blade for good force transfer. Comments?
as are the ball bearing lock, the compression lock, the frame lock, the axis lock, the arc-lock, the tactical action lock, the ram lock, the ultra lock, the button lock, the bolt action lock, the liner lock, the E-lock, the mattlock, the hawk lock, the bolster lock, the sub-frame lock, the vault lock, the stud lock, the ti-lock, the one-handed lock, the self-lock, the axial lock, the levitator lock, the toggle lock, the rolling lock, the ring lockA lot of truth in that. Plus, I don't see people complaining about how their "flimsy" Spyderco lockbacks have failed. The Tri-ad is a good idea, but it's kind of a solution to a problem no one had.
Yeah, the lockbar can slide back a little, but there are no forces in that direction. Once you engage the lock, it will slide forward to stop against the stop pin. I tried it on my Recon 1. With the knife closed, I could use a screwdriver to shift the lockbar back a little, but once I opened the knife and engaged the lock, it slid forward again. That's one of the advantages of the Tri-Ad, it uses the stop pin as a positioning device, while the oval lockbar pivot hole allows self adjustment to mitigate blade play. A normal Lockback design puts all the locking and back stop forces on the lockbar pivot pin, and as the pin or hole ovalizes, more play develops.Is there something at the back of the lockbar that the lockbar rides against so it can't slide backwards? It seems like with the oval 'pivot' hole that the lockbar could slide back some and then the front of the lock would hit the tang and stop instead of locking in place and engaging the tang. The oval hole is there so the lock can slide forward and rest against the stop pin so that closing forces are also transfered to the stop pin but it looks like it can also slide backwards from the picture.
With the angled locking faces it just looks like the lock would need to be all the way forward to engage the tang, at least it looks that way to me from the picture..
