An axe is a machine, unknown steel or not. Unknown is just that - unknown. Every machine is a series of compromises. There's nothing magical, Harry Potter aside, about hickory handles. Wood handles are bulky and easily broken. Bigger heads might generally chop better but they weigh more too, and they don't fold. But let me ask you this. How do you know folding isn't better? I'm not saying it's better. I'm just going to try it out before I make up my mind. What's wrong with that? Answer: not a darn thing. In fact, I recommend everybody run their life that way as much as possible.
Life is compromise. Case in point, my sawvivor is a folding, multi-part aluminum and steel contraption. It works great. It doesn't work as well as a big old bow saw, but it works well enough. Guess what. I'm pretty sure it has some rivets in it too. As it turns out, rivets were an appropriate design choice in this particular case. Who knew?
I don't see why anyone would get so exercised over basically nothing. My thinking about buying a folding axe in no way affects anybody else, including traditionalist woodsmen. No one is forcing you traditional guys to give up anything. More power to you. That's not me. I'm a "make it work" kind of guy.
an ax is not a machine. Machines are powered equipment.
No there is nothing magical about hickory, It can break yes, if swung wrong or poorly chosen when hafting the ax. However one can make a new haft in the filed if needed. Hickory is also warm in the hand, brutally strong and absorbs vibration. The wood becomes polished over use and time, allowing for a smooth hand transition down the haft during the swing. As for not knowing the steel, sure if you buy a Home Depot axe or similar, its gonna be unknown....buy a handmade axe by a well known axsmith, you can be guarenteed of getting very high qaulity steel, albiet at a higher $$$ premium. I have cheap axes for loaners that chip and are dull sounding when hitting the wood,and i have 100+ year old handed down axes that are chip free, with the original hickory haft, and that ring like church bells when making the cut.
A folding ax is COMPROMISE between using it as opposed to using a proper axe. Much like a Multitool is a compromise between using it and a real pair of pliers or side cutters or files or screwdrivers. The tool actually designed for that job will always win out over a compromise and gimmickry.
when swinging an axe when felling a tree, there is a LOT of force involved in the swing, and a lot of impact load. An axe, a proper axe,is designed to overcome those stresses, due to its simple 2 (3 if there is a wedge) piece design. A folding ax is simply not up to that task - at some point , quite early in its use, all those folding points will no longer be able to absorb any more stresses and will fail. ANYONE can see that.
Please do buy one of these and try it out and report back. Try it out in - 30 temps in frozen wood, try it out splitting up a cord or ten of small wood and get back to us. I for one can see the shortcomings of this COMPROMISE tool and will not waste money on it.
I will contionue to use my 100+ year old handed down thru the family hand forged double fit that has felled tens of thousands of trees since my Great granpas time. I will continue touse my german steel Iltis felling ax, and my GB forest ax, because they are solid, reliable simple design tools that well made and well thought out, and are time tested and proven.
Compromise tools are never well thought out, they are a compromise to using a real tool designed for the job.
your milage might vary. If you like compromises (ie: "make it work"), feel free to enjoy said compromises. A fool and his money are soon parted.
Bushman5,
Elitist
