Jack of All Blades
- Nov 12, 2017
40mins of pole beating let’s gooooo
thoery is there, yet good blades are still gonna hold longerAlright guys, greetings hogs
while we are waiting for my buddy to dig up the FBM vid, I got sth to comment on the style of joex testing
It’s imperatiive to clarify that spine wacking is not a scientific or productive means of evaluating a knife.Here is the explanation
Fundamental mechanism
I am going to make an analogy, think of wacking a stick on to a tree, a corner of a wall or anything it can bend and wrap around, what happens?
The stick creaks from opposite the percussion point, and the stick barely hangs together by remaining tissue.
This is due to the portion of the stick traveling with inertia, and the remaining momentum causes an Internal Torque(or Bending Moment) and the farthest point from the nuetral axis is where the internal torque is the highest due to the longest moment arm.
This is very similar to how a crack forms on a relatively strong knife which is able to sustain the initial impact, since knives that breaks at the percussion point immediately upon contact, instead of cracking at the point across the blade is simply not tough enough to resist impact.
Application on a blade
The major geometric difference between the cross-section of a blade and a stick is that a blade has an edge
The edge on the opposite side of the percussion point sustain the maximum internal torque, since the apex is very weak, the blade closer to the nuetral axis, but thicker, takes the major load. If the main bevel is not rigid enough, the maximum internal torque would tear the apex and the crack would rapidly form across the blade, resulting in gross blade failure.
A wider knife would benefit form higher rigidity under force parallel to the blade, and a lower saber grind(stock thickness extending further) blade would benefit form wider cross-section in the higher internal torque areas.
Thus, this testing tends to benefit wide, lower saber ground knives, mainly because they have an wedgier edge that resists elongation better.
The problem with this test
This test suffers from being unable to reflect performance under any circumstances, as whenever you chop or baton, it is the spine which is strong, that is elongated and handles such impacts. In push cutting or slicing, the edge is being elongated, however, the blade is moving forward, thus, no residual momentum is tearing the edge, while the cutting itself is a low stress task.
Thus, this testing is of no reflection of a PRACTICAL strength of a blade, as it is always the SPINE that takes the demanding internal torque
Comparison with a similar yet fundamentally different test
The batoning into concrete block(used by Noss and Cliff and some bladesmiths ) seemed to be an equivalent test, as the motion is relative. However, the major difference is that the blade in a concrete batoning test is supported.
The momentum of the sledge hammer is immediately transfered into the concrete, never really accelerating the blade to a higher speed under which the “tearing effect” due to inertia is significant enough to induce a crack.
The batoning into concrete block is a very scientific test of the performance under extreme conditons against fracture, deformation and wear as well as general strength In a PRACTICAL way.
Conclusion
The joe x style spine wacking test is not scientific nor productive.
He is of no compare to the scientific testing by Noss and Cliff, It’s better to trust the old material and your own experience.
Conclusion
oh no, it turns out busse is all hypeDid not do very well..
choosing a thin thin knife, break out the edge, creating stress piont, so it breaks at the spine wackoh no, it turns out busse is all hype
Guess this is what he wants, using a thin yet wide blade
Absolutely.A fat version of the steel heart would obviously hold up considerably better. But thats the problem with these videos is all the variables arent taken into consideration. He doesnt even use the same testing medium when it comes to the car. Because different parts of the car are far more resilient than others. Something short and fat is obviously going to outperform something long and thin.. at least in a durability contest.
My take away is that the Sharp side did better than the Dull side.
and... Bring on the HOGB8 test!
they ll be useless steel blanks, he got you wrapped around his finger, subconsciusly developing a similar mindset, wrong oneJerry should make a super small and exclusive run of a knife made specifically to pass joes test lol. I bet they would sell.
why it says the original post needs an moderator approval???Alright guys, greetings hogs
Conclusion
