A 850€ (with European taxes) fluke…. Living overseas, as I live, great warranties don’t mean so much as for those who live in the USA. More shipping and more taxes to pay for the warranty replacement…SHBM is a surefire option.
I suspect the blade to be a fluke, joe accidentally got a bad one, I don’t think busse quality could drop dramatically like that, this is not their spirit
Alright guys, greetings hogs
while we are waiting for my buddy to dig up the FBM vid, I got sth to comment on the style of joex testing
It’s imperatiive to clarify that spine wacking is not a scientific or productive means of evaluating a knife.Here is the explanation
Fundamental mechanism
I am going to make an analogy, think of wacking a stick on to a tree, a corner of a wall or anything it can bend and wrap around, what happens?
The stick creaks from opposite the percussion point, and the stick barely hangs together by remaining tissue.
This is due to the portion of the stick beyond the percussion point traveling with inertia, and the remaining momentum causes an Internal Torque(or Bending Moment) and the farthest point from the nuetral axis is where the internal torque is the highest due to the longest moment arm.
This is very similar to how a crack forms on a relatively strong knife which is able to sustain the initial impact, since knives that breaks at the percussion point immediately upon contact, instead of cracking at the point across the blade is simply not tough enough to resist impact.
Application on a blade
The major geometric difference between the cross-section of a blade and a stick is that a blade has an edge
The edge on the opposite side of the percussion point sustain the maximum internal torque, since the apex is very weak, the blade closer to the nuetral axis, but thicker, takes the major load. If the main bevel is not rigid enough, the maximum internal torque would tear the apex and the crack would rapidly form across the blade, resulting in gross blade failure.
A wider knife would benefit form higher rigidity under force parallel to the blade, and a lower saber grind(stock thickness extending further) blade would benefit form wider cross-section in the higher internal torque areas.
Thus, this testing tends to benefit wide, lower saber ground knives, mainly because they have an wedgier edge that resists elongation better.
The problem with this test
This test suffers from being unable to reflect performance under any circumstances, as whenever you chop or baton, it is the spine which is strong, that is elongated and handles such impacts. In push cutting or slicing, the edge is being elongated, however, the blade is moving forward, thus, no residual momentum is tearing the edge, while the cutting itself is a low stress task.
Thus, this testing is of no reflection of a PRACTICAL strength of a blade, as it is always the SPINE that takes the demanding internal torque
Comparison with a similar yet fundamentally different test
The batoning into concrete block(used by Noss and Cliff and some bladesmiths ) seemed to be an equivalent test, as the motion is relative. However, the major difference is that the blade in a concrete batoning test is supported.
The momentum of the sledge hammer is immediately transfered into the concrete, never really accelerating the blade to a higher speed under which the “tearing effect” due to inertia is significant enough to induce a crack.
The batoning into concrete block is a very scientific test of the performance under extreme conditons against fracture, deformation and wear as well as general strength In a PRACTICAL way.
Conclusion
The joe x style spine wacking test is not scientific nor productive.
wouldn’t busse pay for the shipping? plus I don’t think the shipping is going to be nearly as expensive as the blade, just a fractionA 850€ (with European taxes) fluke…. Living overseas, as I live, great warranties don’t mean so much as for those who live in the USA. More shipping and more taxes to pay for the warranty replacement…
I know a fluke can happen anywhere, that’s why I usually only buy high quality products, I trust they have the best quality control, so I don’t need to use warranty replacements. My country customs is a pain in the neck I don’t like to deal with. Having to deal with them two times for the same knife is too much. And I mostly buy custom work, non trivial super heavy duty knives made one at a time, from non trivial alloys. Heat treated one at a time.wouldn’t busse pay for the shipping? plus I don’t think the shipping is going to be nearly as expensive as the blade, just a fraction
a fluke can happen any where ,ok?
But I’m sure Busse would pay for the shipping.wouldn’t busse pay for the shipping? plus I don’t think the shipping is going to be nearly as expensive as the blade, just a fraction
good morning everybody! Joe wrote to me that I needed to find a harder stone. I'm will hit the curb today and I also found some huge wild rocks in Santa Clara. and I will also try two other Busse. I'll make a video.
Jerry Busse will refund JoeX, he is a man of honor. JoeX published in his YouTube channel an email he received from mr Busse telling that.Regarding the warranty. I think they will still honor it. They pride themselves on having never refused a warranty or left a customer unsatisfied. Like someone said earlier, the only thing tougher than a Busse knife, is the Busse knife guarantee.
Joe wants to prove Busse is “promising something they cannot handle”
He will see.
He then said he has no intention of reaching out for the warranty in his youtube comments. He is dead set on the path he has chosen.Jerry Busse will refund JoeX, he is a man of honor. JoeX published in his YouTube channel an email he received from mr Busse telling that.
I want to personally thank you for replying. Joe didn't start that rumor but when I read it I got hot and not only ran my mouth but talked about it in a 30 minute video-Getting a lot of people echoing to Facebook and YouTube that bladeforums is “deleting” peoples threads and won’t let people discuss the test which is absolutely false.
Aus8a and sk85 can most certainly be 60hrc, and sk85 actually would greatly benefit from it. Larrin has done great work and one thing he has demonstrated is potential hardness that are not only achievable to regular steels but the benefits of doing it and at which point those benefits begin to degrade.Had a Barkie in A2 chip twice on wood. With Busse I’ve cut aluminum poles in half on concrete with little edge damage that was caused by the concrete below the pole.
Rewatching the video the amount of effort he’s pulling on that thin anorexic tip is amazing. Cutting through the car door with zero edge damage. The only thing that seemed to damage it was cutting through rocks at 60hrc.
Aus8, sk85, and machetes certainly aren’t 60hrc.
Edit: And after the things he said about Jerry's wife I don't think he deserves a new blade anyway.
I expected nothing less. But it still shows who is the bigger man that he doesn't even address the elephant in the room.Joe X posted this on Youtube a few hours ago.
JOE X
2 hours ago
email from Jerry B.
really nice from him!!!
"I saw your AFBM video and would request that you please return all of the pieces to our shop in order for us to examine them.
Our warranty does not cover "Intentional Damage". However, I did tell you that I would be sending you an INFI blade to test and failed to do so in the time-frame I quoted you. Since you paid us for the AFBM out of your pocket, we will issue you a Full Refund, including S&H upon receipt of the parts and pieces.
Thanks,
Jerry"
I didn’t mean those steels couldn’t be 60hrc. The ones Joe x tested certainly weren’t 60hrc.Aus8a and sk85 can most certainly be 60hrc, and sk85 actually would greatly benefit from it. Larrin has done great work and one thing he has demonstrated is potential hardness that are not only achievable to regular steels but the benefits of doing it and at which point those benefits begin to degrade.
