Originally posted by Ed Fowler
Steven Roos: I learned early in the game that the greater the the degree of mechanical reduction by forging at appropriate temperature for the steel and in the right manner the greater the potential for increased performance. I do not know what the limits are. I do know that I never had a blade from a 2 inch ball out perform a blade from a 3 inch ball. The five inch stock we use now produces blades that highly out perform the old blades from 3 inch stock. This may be due to several reasons, this steel is very clean and consistent, all from the same pour, a tremendous advantage!
We plan on an experiment in the future starting with a 10 inch or greater size round bar. We will turn the same stock down to several diameters, then forge the resultant bars, (all from the same larger bar) and compare the blades. It is going to cost money and time, but hopefully we will be able to determine the limits of the advantage to the potential blade performance.
Yes it is very labor and time intense working down larger stock. I do it because I deeply want to achieve the highest performance blades possible. It is not within the possibility of many blade smiths who work totally by hand. I would very much like to determine what is necessary and also learn ways of enhancing blades from smaller stock.
Many variables influence the nature of the steel, some are within the realm of all of us. Most significant are many low temp thermal cycles, both while forging and planned normalizing cycles between forging steps. Not to forget heat treating stuff. I could state lots of variables we are working with now, but they are unproven and could be confusing. We will share them when we are sure we are right.
WE hope that the new shop we are building will afford the opportunity to bring together knife makers who share the desire for high performance blades. The more individuals involved the quicker we all learn.
