- Oct 26, 2014
Let's end the weekend with a little abalone.
Hi David i just got a #25 in Goldenrod jig bone and have been playing this mod over in my mind , but have been thinking Dremel as that is what i have but what you used is clearly not a Dremel, it looks as if you clamped the knife in a bench vice and bought the grinding wheel down freehand using an electric drill , could you please tell me the specification of the grind wheel so that i can order one, thank you in advance.
PS luck did not come into it, i am guessing a firm hand a steady eye and perhaps a silent prayer , anyhoo it looks like a fine job to me.
Polished second cut stag.View attachment 781207
I had an optimistic good feeling of what it would look like. I really liked the third cut stag TC Barlows from a few years ago, but this stuff has more inclusions.I really thought the polished stag was going to be my least favorite from this run but it turned out to be the exact opposite. I love mine. Yours looks perfect!
Hi Oldmanrunning, sorry that I am replying to you so late. I have been busy at work and I just saw your message. Attached is a photo of 3 different grinding stones that I used to create the EZ open notch. You are very observant and correctly outlined exactly how I performed the procedure. I used the smallest stone first and worked my way up. Good luck with your modification!
Hi again David, i had gone ahead and taken the plunge but was not real pleased with the outcome, so i let it sit for a while and took another swing at it but was still not sure so i let it sit some more before taking what i hoped was my last shot, well after some grinding and buffing it was OK ish, i showed it to a fellow knife nut, "I have seen worse" he said, talk about being damned with faint praise. Then i saw your post with the stones you used, so i offered up a prayer to the saint of dumb asses and took my last shot with the full range of stones and if i do say so myself it aint half bad, the finished job looks a bit like the two knives in post #1873 by joeradza , wide enough so my thumb fits exactly in to the notch but not to deep , i guess it could do with being a touch nearer the centre rivet but it works ok and after steeping it in my coffee grounds to colour up the white of the ground bone i am pleased with it and if i finally figure out how to post pictures i will put some up here.
