GEC 68 Pony Jack 2021
is it a true scratch or a rub mark? the white owl being a single spring means the blade would be a touch canted
When the blade closes it passes by a square shoulder on the tang of the secondary blade..... I'm sure that is the origin of the mark.... Possibly the blade was sprung into the shoulder, or the shoulder had a little booger on it..... It is a very tight fit in that area.... I can pass a sheet of printer paper on both sides of the blade so it is ok now..... I'm not in a dither ...... I might try to touch it up ... or, leave it as is and call it a beauty mark..... At my age I don't do anything in a hurry other than get to the bathroom when my diuretic pill kicks in in the morning.......
I don't see much if any crinking..... I think the two blades were offset ground to allow for overlap without collision........ They did a nice job of machining.....
Will be curious to see if this is common with this run.
It is common, mine is just developing (blade rub). There is also an area on the inside of my pen that is striking the top crown of the clip when opening and closing the pen when the clip is closed. This is common with single spring knives with blades opening in opposite directions with nothing between them to prevent blade rub. I have a few that don't including a couple 62's, and all steel 2 blade stockman's, but some do. You're pushing one blade into the direction of the other to open. If there's not enough strength to resist it, it will rub. Pull the main blade straight up and out, then pull out the pen and drop the main back in to minimize it. If it's going to be a user I'd just leave it as it will happen again. This can be the one downfall to the single spring opposite end bladed knives.
I agree that blade contact on single spring knives is common, and the tolerances are so tight that light finger pressure can cause an otherwise perfectly made knife to rub blades.
Normal use will cause blade contact from finger pressure on opening, but that is the price paid for 2 blades on one sexy svelte spring.
I understand this is common with single spring multi-blade knives. I also know that many of us on this forum put a high premium on a knife of this style that doesn’t exhibit rub. I think it’s a detail some are interested in which is why I mentioned it. My 33 has the same on the pen blade. Not a deal breaker for me.
I have to admit, that is going to be a bit of a bummer on the main blade. Wouldn't mind as much on the pen. Not a deal breaker though.
As i mentioned previously, my 62's are the same thickness and don't do this, but I believe this is due to the master wharnie being so thin, there is more clearance between blades.
That's mounting guard very keenly :cool:
I am more of a fan of the Double End rather than the Jack but that one looks smart. For those annoyed with potential blade-rub there are two answers: a) Use it constantly and get it patinated and you won't see scratches, rubs :cool: b) Keep it entombed in that tube and never once open it....;)😆
Thanks. I've liked jacks since I was kid. More recently I've become fond of double ended pocket knives also. I think the elusive White Owl, will remain, um, elusive for now.
You forgot c) Buy a Pony Jack :)
@mbkr You are likely right about elusive, the Owl is a creature of the night and dislikes too much early rising :cool:
As for option c) I've far too many Jacks that remain unused, don't really like the bulk, all for that little Pen blade ;) but there's no such thing as one COOL fits all, fortunately :D
I too have many Jacks and EDC a few, but favor double end single spring, or single blades as the tend to be thinner and lighter in the pocket. That said, I have played with and carried both, and with the size of these particular models the difference in size and weight are very nominal.
For me, small jack knives like the 68 or 14 are too thin and light in hand unless they are two bladers. I like the extra bulk of a second spring.
My Pony Jack arrived today and low and behold if it aint the spittin image of one of my favorite edc fun knives, the Imperial/Hammer equal end jack.
Now, if GEC is going to make another 68 then they absolutely, clearly, must make the next 68 after the Hopalong Cassidy. The Hopalong 68 in ebony. Yeah baby, sign me up! Are you listening Mr. Howard? I promise I will buy one!
Don't tell @JohnDF about these if your request is heeded.🤣🤣🤣🤣🤣🤣
@r8shell Interesting what you wrote about the 14. It's a difficult pattern for me, difficult in that I admire it a lot but just can't use it. Neither the 2 blade Jack nor the single feel really right in the hand. True, the 2 spring offers a bit more bulk but the handle is not really wide and this contrasts with the 15 that's only a 'bit' bigger but is really good in single-blade form.
Can't agree with you about the Owl though, big fan :) but what is remarkable is that the Pony Jack and White Owl, despite being on the same frame really are two completely different knives, and that can't be bad;)
Regards, Will
