Sando said:Wow, that stuff sounds great! I'm gonna have to see where I can find it.
Steve
galadduin said:Steve,
I think I found a similar product, though this is more advanced I guess. I has too much advantages, like vibration, chemical and high temp resistance, excellent gap filling etc.. I think this is very similar to Hyper-Flex:
Permabond:
http://news.thomasnet.com/fullstory/31272
also here is another
Surlock Teflon.
http://www.surlok.com/tds/1567.htm
Or try another anaerobic pipe sealant which is most available for you.
Dan Gray said:but both need to be Mechanically attached because..
they both say ...
galadduin said:Ok, it is what they say, but my test still hangs on in dish washer and impact test. It is only two clamped flat steels, no pin, no hole. May be clamping is mechanical enough..
Edit:
Also it is an advantage IMHO for it is anaerobic, It stays liquid outside, when clamped it is too easy to clean the sides, no visible traces of the adhesive left, no sanding is required, just rub it with a piece of cloth, voila...
Sando said:galadduin,
Keep the test going! I'm all ears.
You know I was really discouraged I my test didn't really reveal anything I wanted to about these 'glues'. So much so I wasn't going to try again.
But, it's been a couple of days. I think I'll start over....
Steve
galadduin said:NOT clamped in the dish washer for sure! The clamps were off after cure time was over
