Goncz Titanium Knife / Flashlights
i'm happy to see this thread back in a happy mood :D
mr goncz, have you considered lending or donating your lights to be "professionally" reviewed?
there are a number of amazing and knowlegable reviewers who will review your lights in an honest and open manner free of charge.
some that come to mind are:
http://www.ledmuseum.org/
http://flashlightreviews.home.att.net/index.html
http://torchreviews.net/
those are some of the "main" reviewers, and have a wide selection of lights to compare to and would be delighted to review your products.
while i have never done a review, i would even be happy to do a minireview of one of your lights also. my expertise is primarily limited to led's (of which i have created more than few myself), and would be happy to provide an honest review.
having a positive review of your lights is one of the most important things you can do as a flashlight manufacturer. review sites get thousands of hits, and many people refer to them before making a purchase decision.
sifu1a, huh?
i've read this entire thread, as well as every thread on cpf involving or refering to goncz...some of them more than once!
WOW!!! Two days and no response from g.b.! I am once again amazed at the judicious restraint shown by him at not jumping at the opportunity to actually test the light devices. But then again, why bother with further testing the flashlights when they have already been selected as the end-all be-all by desert dwellers who wish to illuminate stop signs. :eek:
Ooofffaa!!
Stuart
Its not GBs judicious restraint,it's more likely restraints applied by the medical staff along with some good meds,or they wont let him have computer access in the wing for people with THAT problem.
WOW!!! Three full days, no response from g.b., and counting!!!
Could the offer of actual test facilities have been too daunting for our anti-hero? :D Just kidding g.b. Please tell me about your newest super-equipment and perhaps exactly who is actually using same.
The very best holiday to all!!
Stuart
With the recent outrageous claims on his new multiple-hundred lumens LED flashlight JG re-sparked my interest in his 673 lumens claim for the M3 using the high-output bulb.
I think I pretty much nailed it now.
His claims had been for a measured 673 lumens at 9V and somewhere else he mentioned a 3.1 current draw.
My measurements show the actual bulb in the M3 to draw ~ 2.7A when used with 2 18500 LiIon cells and dropping the cells voltage to ~ 6.8V and when used with 3 123 cells (the standard config of the Goncz M3) it draws 2.5A and drops the cells voltage to ~ 5.8V.
All these data points suggests or confirm that the bulb used is the WA 01274 which has a design voltage of 7.2V and draws 2.77A there and is speced to produce some 553 lumens then.
Now taken as a given that JG really measured the bulb in one of his lights using a bench supply to get the claimed 9V supply voltage and that the 673 lu are accurate one could calculate that using the actual 3 123 cells and taken the relation between measured flashlight output at 9V (overdriven by 25% it would theoretically give you a 220% brightness increase - while underdriving it by 20% as in the case of 3 123 cells gives you a meager 46% - in the case of the 2 LiIons its minus 5% voltage and 83% brightness) which would be a theoretical bulb oputput of 1216 lu vs measured 673 lu which is probably OK taking all relevant losses into account one would arrive at a theoretical measurement of probably around 140 lumens which would fit the results seen by people using the M3 that it compares against the 105/120 lumens Surefire lights while beeing drastically yellower in output - obviously a result of heavily underdriving the bulb.
My recent reports that using 2 1400ma 18500 LiIons had been very much improving the results is now also much clearer - at only 5% underdriving and 83% brightness one calculates 255 lumens and comparing it against a P91 driven Surefire its coparable while still being yellower and having a worse beam, but we´re getting there now with those Li-Ions.
To explain my calculation:
Stock WA 01274 at 7.2V gives 553 lumens
Overdriven by 25% (9V) gives a theoretical 1216 lu and JG claimed 673 lu - which is ~ 1,8 I will use as a corection factor. This is a quite typical loss starting from the single bulb output until the beam gets out of the flashlight lense.
Calculation the underdrive using 3 x 123 or 2 x LiIon this gives us:
WA 01274 at 5.8V using 3 123 is minus 20% voltage at 46 % brightness so 553 lu x 46% / 1.8 ~ 140 lu
WA 01274 at 6.8V using 2 LiIons is minus 5% voltage at 83% brightness so 553 lu x 83% / 1.8 ~ 255 lu
I think this mix of measurements and theoretical math gives pretty accurate results which do conform pretty well with real world testing and reports and would results in some factual statements regarding the Goncz M3.
The Goncz M3 primarily lacks a fitting joice of bulbs resulting in way underdriven inefficient output and the reported much too yellow beam.
The Goncz M3 could be easily improved by either the use of 2 high-cap LiIon cells or the use of a properly selected bulb
The Carley Bi-Pin to PR base socket specified at 1A is used well over his design specs at ~ 2.7A in the Goncz M3
John Goncz reported claims of the M3s 673 lu might be true for bench-supply testing of the light and bulb combo but nowhere are indicative of real-world performance of his flashlight.
John Goncz seem to be unable to understand the concept of voltage drop when cells are used with high loads which question the credibility of his multi-million dollar engineering efforts.
It is a shame that a flashlight with some unquestioned nice new design ideas and which has been tested and some shortcomings reported doesn´t get improved upon easily to be fixed issues but the manufacturer starts to behave unprofessionally to the highest degree.
I really ask myself why I don´t leave the guy alone - at this rate of multi-million design efforts and corresponding results this post would be well worth a couple of billions :D and I probably won´t get anything besides further insults from the guy :confused:
But Mr. Goncz - just take it as my christmas present to you - and for all other readers - my very early sentence about taking care not to be "Gonczed off" your money is well prooven by this I would say.
Klaus
BTW - I would still appreciate receiving the paid for replacement bulb and the paid for and as advertised borofloat lense :p
in addition to what klaus has said above, i would like to also point out that the optical package is not very efficient (of course this holds true for all flashlights, and goncz lights may not be any worse...having not seen any of them in person, i won't comment on that)
i forget the actual numbers exactly, so please understand this is a ballpark figure.
the borofloat lens (if using the borofloat lens....some have said it's a polycarbonate lens), the optical purity of the lens should be *somewhere* around 95 percent (maybe be 93, may be 98, i really don't remember)
a polycarb lens would be even lower, something along the high 80s if i recall correctly. again it depends on a number of things, such as scratches, chemical marks, even the brand of lens used.
the reflector itself isn't very efficient. reflectivity probably hovers somewhere beteween 80-90 for most high-quality reflectors (again, this is from memory, and i've got a horrible memory so it's likely that these numbers aren't quite on). depending on how reflective the goncz reflector is (i'll let you all decide how good you think it is ;) ), you will loose more light. also remember that the light isn't bouncing off the surface only once, some of the light bounces from wall to wall to wall.
then of course there are gaps between the bulb and the reflector (light out the bottom) light is being soaked up by the orings touching the lens, etc, etc ,etc.
basically, what i'm saying is that even if the bulb *was* producing around 600lumens, you'd get a *whole lot* less than that actually coming out the front of the light.
i know arc, surefire and some others rate their lights using "reflectorized measurements" this means that instead of just testing a bare bulb to see how many lumens it puts out, they put it inside the light, then take the readings, so they actually know how much light is coming out the end. as explained above, this is a much more acurate and honest measurement.
Rothrandir & Klaus:
I seriously doubt that g.b. will ever be able and/or willing to respond to the above in as technically eloquent a manner as you both have put the details. Thanks very much for the technical info and detail as to how lights are actually tested by professionals. Sorry to hear that Klaus has still not received the purchased lens and bulb. Perhaps g.b. needs those few $$ for more technical development? Now back to the desert and more stop signs to be illuminated!!
Here's to a very happy holiday to all!!
Stuart
I do not read anything that is new to us. For general public is educational and that is fine. The figures are somewhere in the ballpark.
As to any advice from a less capable... thanks but no need!!!
As to GEB (LED) Goncz Electron Beam light is packed into the M-2 housing and is delivering 150 lumens culminating focusable light. Other feature is that if You want to change to regular light, You just take the GEB module out and replace it with regular bulb: easy and inexpensive, and maitains the water proof statues!!!
As Our lights capture more lights due to the deep reflector that capture more lights, than any other in the World.
The informative Thread!!
Oh great - finally you are admitting that you KNEW about the real (much lower) numbers and still using your inflated claims then wouldn´t that be something of bad smell or even be outright illegal ?
And in regards to less capable - thanks for that - at least you realize that not all people are as capable as you when it comes to inflated marketing claims and gonczing people off their money :D
Klaus
Hi folks, I had to come back to clarify some facts:
John posted this:
Cost Surefire 3 ceell : no idea
Ours : $65.00
Ours: Watterproof
Goncz Threadless focusing
Bulb replacement: Sure fire $25.00 to $30.00
Ours $8.00
Output light least twice as much
Ours : Spare bulb in the tail switch
and many more...
[ENDQUOTE]
Well, a 3x123 SF light (the Z3) can be had for about $85, the MSRP is $108. A P91 high output SF LA is $25. Goncz bulbs might be cheaper, but are obviously unobtainium, since John hasn't delivered the promised spare bulb and borofloat lens to date. The output of the GM3 should according to my personal experiance and Klaus' math be max. ca. 140lm (which is already a generous figure) with a much yellower color tint, compared to ca. 200-225 lm from the SF LAs. In addition to that, there was no spare bulb in the tailcap of the M3, there's not even room for one. Even with the mentioned threadless focussing mechanism (a nice idea), I could not achieve a reasonably focussed beam, the GM3 is more a flood light, but this point cannot be used to critisize the GM3 per se, functionality lied in the eye of the beholder and one might want a flood beam. Actually, I do most of the times.
Next ... the 600 lumen LED light. FYI, our most advanced and crazy modders on CPF managed to squeaze out about 216lm from a 5W Luxeon Star in a highly overdriven setting (MR Bulk's Space Needle II or the MR-X), and this is confirmed by a lab with an integrated sphere. Even when taking into account that the SNII used a V-binned emitter and that nowadays you can get X-bins (better efficiency), 600lm are not possible from that kind of setup even from a theoretical point of view with a bare emitter, and then you have to think of all the losses that occur when using this emitter in a flashlight, like Roth mentioned above. So ... forget this 600lm LED light, unless of course it would be a multiple 5W-LS light and was crew-operated due to the massive size and heat-sinking necessary. John later mentioned 150lm in a 2x123 setup, this actually sound more reasonable, although still quite overrated IMHO.
John, you do not need to send me the borofloat lens and the spare bulb any longer since I gave away the GM3 for free to Klaus; I do not need them any longer.
regards,
bernhard
OUTSTANDING!!
FINALLY! Real statistics with REAL laboratory information mentioned! Now this can finally be called the "informative thread" indeed.
The only problem is that g.b. has already proven time and again that he is VERY dangerous with the small amount of information that he has and he might just attempt to twist the afformentioned into something else. :rolleyes:
It would appear that the only satisfied "tester" of the lights sent out by g.b. is The Bad Guy, unless I have misread some of the prior posts. Not to attempt to put any of the regular members on the spot here but it would be interesting to know how this test light has performed to date. I believe that in all fairness and up until several weeks ago, The Bad Guy has reported good testing results.
Now the big question; It would appear that the only actual "improvement" made with the goncz light is the perpetual focus head or "threadless" as he advertises it. Just what "true" benefit is an adjutsable beam of this type given consideration that there are serveal other highly reputable manufacturers that already make adjustable lights and just how often is an adjustable beam used? Personally and by way of a quick Q/A we do not really find the need to focus the beam of a flashlight in the field and the possibility of a preferred flood light needing to be refocussed from a more narrow beam (or vice versa) in a split second and with other more prudent issues in mind would be more of a hinderance. Kind of similar to readjusting sights seconds before an engagement. Personally and strictly from a tactical point, it would appear we would rather know exactly what to expect from the light as it is deployed and not need to refocus.
Now as to a more recent revelation; A g.b. gerbil crew-served lighting device. Now that is a marketing idea that g.b. SHOULD pay Kiessling for!! Heck, g.b. could replace the monkey and music grinder with a show like that!! :D
All the best in the new year!!
Stuart
GONCZ GEB LIGHTS
Just to clarify:
If a 5 Watts LED provides 120 to 150 Lumen and overdriven gives You additional 10 to 15% In a deep culminating reflector we capture most of the light, and here we are speaking of M-2 and M-3, So You make the call.
When it comes to the big M-5 Electron you have 4 x 5 Watts and is captured in a 3 inch diameter and 3 inch deep reflector with smooth surface You have awssome light and in any calcculation you up at the stated Lumen and the distance reach is unmatched.
It is a dream for underwater Photography with 5500 Kelvin !!!
The informative Treads!!!!
Happy New Year!!!, Boldog Uj Evet!!!, Gluckliches Neues Jahr!!!, Nuevo Anos!!!, Srecno Novo Leto!!!, Srecno Novo Godina!!!, She, She!!! etc.
GONCZ GEB LIGHTS
Just to clarify:
That's absolute GIBBERISH!!!!
HUH?? :confused:
Perhaps thats what the G in GB stands for. Not gerbil boy.No one has ever accused Goncz of mastering the english language,perhaps massacre.
John, in a 4 x 5W LS light you'd need a lot of heatsinking to run it safely since all the heat generated by the inefficient LEDs is not blasted away with the beam as IR radiation but must be bled away via the light, which is very difficult at best for this configuration. In addition to that, even when using a very large and deep reflector, your light sources (4 x 5W LS = 4 x 4 x 1W LS since the 5W is basically 4 x 1W die in one package) are much too dispersed to give you a reasonably well throwing beam, the result would be a flood light with lots of beam artifacts due to the mentioned smooth reflector. Further more, this beast would be very power hungry and need one hell of a power supply with low internal resistence to keep the juice flowing. Pair that with the inherent voltage instability of batteries under load and you'd need a regulating circuit of some sort which would then add to the heat problem it's own inefficiency.
I'd be very much interested in more info on this concept! Do you have a completed prototye of some sort to show off?
bernhard
a note for Stu: the question of adjustable focus vs. fixed focus is a difficult one and touches philosophy as well as personal preferences. IMHO a focus mechanism of some kind cannot be considered a drawback, it is just a feature you like or dislike, like so many others. This threadless quick-focus John invented could have been nice if the light (my GM3 in this case) would have been able to achieve a narrow beam.
bernhard
Kiessling:
A quick question re: the "threadless" focus on the light that you examined. Was it a tight fit or did it spin freely? I'm curious as if it was easily spun then my earlier reference to the light being knocked out of desired focus would stand. However, if it were a tight fit then it would possibly be an interesting feature for search and/or tactical use.
Stuart
