RokJok
- Oct 6, 2000
TechLite Lumen Master -- Cree LED, 150 lumens, 3 ea AAA batteries, tail switch, and it's got that flashy-mode for you.
http://www.amazon.com/TechLite-Mast...ical-Flashlight/dp/tags-on-product/B003VCL4XQ
I got the 3-pack at Costco for $15, so that's $5 per light for all you math-challenged Hogs.
In spite of mixed reviews, all 3 of mine have been dependable so far. I don't know if they are marketed as waterproof, but mine have stood up to rain okay. (edit to add) I see most of the negative reviews are for an earlier generation of the Lumen Master light that has a low-battery LED on the tail switch. My lights have a black rubber switch cover that precludes the lo-battery light.)
Something that I don't care for so much is that they have three modes (half, full, flash, plus off) and you have to cycle through the modes sequentially. i.e. first click from OFF = 1/2 strength, next click = full strength, next click = flash mode, and another click gets you back to OFF.
I don't see a lot of difference between the first click (half-bright) and the second click (full strength).
Size format is decently small for BDU thigh pocket, though maybe a bit large for front/back jeans pocket carry. The facets cut on the bezel shroud are just enough to keep it from rolling on a relatively horizontal surface. However, if on much of an incline they prove insufficient to hold the light in place.
(edit to add) Upon closer inspection, the facets in the bezel shroud were cut with a round-nose cutter. This geometry yields a narrower 2-bearing-point contact area than would have resulted if they had cut a flat facet on the bezel shroud to the same depth as the round radiused cut the lights currently have. I may take one of these lights and file the facet flat to the depth they cut the rounded cut to see if I like it and can stand the resulting contrast between the black anodized aluminum and the newly exposed metal from filing. That filing will effectively widen the facet = longer line intersecting a wider chord of the bezel's arc = better stability).
I find the body knurling plenty aggressively secure in grip.
Length: 4.5" (11.43 cm)
Max Diameter: 1.3125" which is 1-5/16" (3.33 cm)
Weight (incl batteries): 5 oz (140 g)
