- Jan 10, 2015
Bob, the reason I like the combo of carnauba and beeswax is that the bees wax makes the carnauba just soft enough to be able to apply by hand to your tools, even in the field where you do not have a buffing wheel.
And are you keeping your file clean? Taking the file card to it every minute or so?
yep, I clean it often with my wire brush. I'll give it another go sometime, but she's tough that plumb.
None of my factory assembled axes are dead straight. What you've got is minor and will never be noticed by the majority of folks that choose to swing it.
really? Okay, I am going to attempt to take a bit more off to try and straighten it out and we'll go from there as I might just leave it. Thanks Agent, That is along the lines of what I was trying so I'll give it another go.
The major thing that I learned with this hang that I was doing wrong before was once I got the eye to fit on the bottom, I don't modify the top of the wood anymore. Previously, I had never thought about it, so I kept inadvertently shaving from the top area to make the middle and bottom fit with the rasp. Which is why in the end I had such a small fit at the top. I'm glad I sorted that out!
If it's a tilt from toe to heel, I have found removing wood from the top of the eye on one side, and the bottom of the eye on the other side will usually get it straightened out.
No problem, I just get out my board stretcher.. . . "Darned; I've cut it twice and it's still too short!".
is it okay to heat up the head in boiling water to get it hot enough to sizzle liquids on it? From that other thread, that's how hot it needed to be I think. Just curious if that's a safe way to heat up the metal without ruining the temper?
Know what? Get out there and use it just any other age-old seemingly unappreciative owner would have. Stick it in a stump and leave it in the rain and sun during the day and don't go out of your way to remove pine pitch or spruce gum until it becomes a nuisance. The head will then develop it's own colours fast enough.
