The axe ended up being toe to the left after I drove the wedge in, I got pretty frustrated with that. But I took her out today and bucked a good sized piece of pine (after chopping and having fun for a bit, I got down to business):
I put some BLO on the sides before I drove it in, would that be the cause if it hasn't dried enough yet?
Thanks guys, hey Bridger, this is the 1.75lb variant (just letting you know), and this length really does feel fantastic.
Agent, I pounded the wedge back in, I'm going to leave it for a couple days and let that oil dry 100%. Have you had a wedge start to pop out like that before? What part is the tongue? Sorry for my ignorance.
I have another question for you guys, what method do you use to drive in your wooden wedge if you don't have a mallet?
I tried hitting a 2x4 with a hammer last time on top of the wedge, I don't think enough energy transfers to the wedge. Any suggestions?
I use whatever steel headed hammer I have handy. With the bottom of my axe handle resting on a rubber floor mat I drive the wooden wedge. I look every so often to be sure the head is not coming up the haft as I am driving the wedge. If it is I just slam the haft hard on the rubber floor mat driving the head back down(I hang the head while I still have a squared off fawns foot.). My wedges never go in in one piece. They always split. I want them to split to take up the uneven spaces between the eye and the haft. I drive the wedges hard and far enough that I get a sense they can go no further and want to or start to mushroom. Then I trim them off.
I prefer a softer wedge than the haft but will use a hard wood on occasion. My wedges have never backed out.
It might not be the right way to do it, but it is my way.
garry3-nothing wrong with your way. The only thing I do different is I drive the wedge with a carpenters 's wood mallet I made from osage orange. I also have never had a wedge back out, and that is on a lot of hangs.
Have you ever heard of cracking an eye by over driving a wedge? It seems I have been told that but I can not remember by who. Just want to separate the wheat from the chaff. Sometimes things have a basis in fact.
I've cracked an eye while wedging before. Happened to my True Temper broad hatchet. I figured it was a bad heat treat. I had a buddy weld it, I re-hung it and it's been fine for 5 years now.
Yes. Drill a pilot hole first so only the threads are grabbing so the screw will not wedge it more. Use two screws, one on each end.I want to try and pull it out, but I am worried I will screw that up as well, and have a messy wedge that is tight. I was thinking about using screws and try to pry it out, any advice on that?
