Hey Justin,
I've been hanging out at KnifeDogs, because I've met a number of people in person that hang out there. I just checked and my outlets are split on two 20 amp breakers, so I should be ok. I will have to forgo a 220v setup unless I run an extension cord and unplug my oven or dryer!!!
I was thinking that having a one speed grinder might bump up my failure rate, because of the high speed. Now, is the 8" wheel for heavy metal removal and smaller wheel for detail work? I see some setups without the big wheel, so I was wondering what it was used mainly for? Would you recommend the multi-platen setup or the standard platen version? What rpm should I get on the single phase motor, would 1800rpm be enough, or do I need more?
Thanks,
Jeff
Thanks,
Jeff
Haven't seen you post lately, Jeff. Good to see you're still knockin' around on here. This grinder kit is not ideal for a multi-speed pulley set-up. It could be done but you would have to mount the motor off the base and add pillow block bearings and an additional shaft. If you want variable speed with this unit your best bet is to get a 3 phase motor and a VFD to drive it. If you do go this route I would personally suggest you go to a 1-1/2hp motor, from what I understand you lose some power to the VFD. For a single speed setup you can get by pretty well with 1hp. At least until you can upgrade.
FWIW mine is set up with a 1hp single phase, so it is single speed. Having a single speed grinder is better than having no grinder. If you want to get set up as cheap as possible I would suggest scavenging a used 1hp single phase motor if possible, or get one on Ebay. They can be had pretty cheap. As finances allow you can swap this out for a bigger 3-phase and add a VFD.
The beauty of this kit is that you can mix and match parts/motors easily, so you can go cheap to get it running and upgrade as you go.
Before you decide on a motor you might check into your circuits to be sure you get one that won't pop your breakers when you turn it on. A 2hp motor usually requires 220v so this is something to consider too. This is why both of my grinders are 1hp.
