Thanks, Doc. I'll try that. If you don't mind, sling me the name of the seller and I'll see if they have any more.
Keith
The spacers are for the tooling arm slots, depending on what material you use for the tooling arm(s), you might need the spacers to make the slots wider. I got by without using them, the square tube I had was slightly rectangular, fits into the slots one way but turn it 90 degrees and it won't fit.
I used a nut between the wheels and the platen assembly/tooling arm. I had some spacing/alignment issues with both the small wheel attatchment and the platen assembly, partly due to the short shaft on the motor I had.
I have the tension arm bolted directly against the upright, with a washer on the back side of the upright.
