If you stare at it long enough it will probably wear off, I can only imagine what some epoxy remover and a scrub pad would do.
However, Joe, the HK does not come in satin. If/when I get one I will strip the coating in order to acid stone wash it.Brasso with 320 grit wet/dry sandpaper for a start, and ending with 3M pads...a lot of work, done to my 710D2 where the coating failed. Take into account the blade was textured at the factory which took even more work to smooth it down. The end result was good, but I'd never do it again by hand. Real world advice, use the knife and if what you really want is a satin blade send the knife up to Benchmade and have them swap out the blade. I think it's $25.00.
Sorry to bump an old thread, but I almost just made a post about this. I bought this knife for $105 shipped from bladeHQ... can't believe how great of a deal this knife is, and yet no one is talking about it. The fit and finish on mine is better than the fit and finish on the Rift I received, yet was significantly less expensive. My only guess is that people don't like it because it is branded HK...
Fine to compare the HK 14715 with the Stryker 908BK which goes for $165.75. Blade and handle are more similar (Clip Point vs. drop Point as opposed to Reverse Tanto on the Rift) in shape but the blade is 0.1" shorter. HK 14715 is still $70 less.
As an aside, one of the main reasons I like the 940, 810 and 950 so much is exactly because of the Reverse Tanto blade.
But what I'm not getting is the comparison to the Rift? Why the Rift I guess is what I'm asking?
Drop Point / Spear Point blade vs a Reverse Tanto. That seems very different to me right there?
The 14715 is a clip point, just like the Rift. Look at the cutting edge and tip of both knives, ignoring the back of the blade, they are very similar. A Clip point is no more a "reverse tanto" than it is a "lightsaber", in spite of what BM calls it.
At the time the comparison was fist made, the 908 was not released, so the Rift was the closest hard use knife to compare it to. If you lay the blades on top of each other, the cutting edges are almost the same: same length, same belly, etc. They both have full liners, G10 scales, Axis lock, yet the HK has a D2 blade vs. 154CM, and still costs a heck of a lot less. That is the comparison being made.I recently received the HK 14715 and like everyone else think it a great value and great knife on all counts.
Here is quick size compare. (I didn't take it with Adamas, but it is shorter than 810.
940 vs H&K
950 Rift vs H&K
581, H&K, and 810
