Not to change the subject but you must be married. Sorry, I couldn't resist.
Well I've been married, how could you tell?
I like the idea of a countdown clock.
Why is this knife H1? VG-10 would have been better, as I see it. Is H1 cheaper or more functional for a fighter in any way?
Well, I have used H1, and it does get better, but initially, it sucks.
For a fighter, a knife that will not a see a lot of practical use, H1 makes no sense to me. You act like conventional stainless is 52-100. Rust is rarely an issue with stainless steels that have much higher performance than H1.
the knife was originally developed for the Israeli special forces and in a combat situation having a blade that will not rust has it's advantages . even good stainless steels can suffer from minor corrosion , which can lead to tarnishing/pitting at the cutting edge .
This is a bit of an exaggeration. H1 makes little sense.
I have never, ever had pitting at the cutting edge of any knife I have used, carbon steel included. To think that any application that a fighter would implicate would cause edge pitting in a stainless steel is absurd.
Any benefit that it would garner would be much outweighed by better wear-resistance and edge stability.
You people far, far overestimate the dangers of corrosion.
That is my final statement barring more significant input.
i agree , for most people they will never encounter a corrosion problem , but this knife wasn't designed for the average person , it was designed for the Israeli military to be used under specific harsh conditions . after much testing H1 was selected because it best fit there criteria , im pretty sure if VG-10 would have worked better for there use , the warrior would be made out of it .
p.s. VG-10 isn't used in diving knives , maybe because it's not optimal in a salt water environment .
Well, if part of the intended use is being covered in salt water all the time, then I guess it makes some sense. Why not compromise a bit and use 440C?
I might aslso add that the serrated H1 Jumpmaster had better edge retention than any other blade tested.
sal
