- Jul 30, 2006
I think they do, but am open to correction. I don't have a full size alox model. But they have the same configuration as the plastic covered models, do they not?
Do they have springs that should be exactly aligned with each other and the frame in both the opened and closed positions like a trapper or stockman does? And are they right on outer edge of the knife where your fingers feel any imperfections as they grasp the knife? My Red Tinker does not. Nor do my Classics. Nor did my Camper.
My secretary model does have the spring visible, but it is recessed and unless you look you don't notice that it is not aligned with either the handle or the frame. Of course once you look you also see there are gaps between the spring and the frame that would cause screams of outrage if those gaps were found on a Case or a Buck.
And the joint between the blade and the spring in the opened position. Is it not recessed so that if it is a bit out of alignment it really is not noticeable?
