- Sep 25, 2007
Now the skinner...
I'm happy with everything about the shape/style except for the "thumb divot" I ended up with along the back spine (above the serrations). I initially wanted to put some jinks in there, tried to, didn't like them, so had to grind them out. The result is the divot
mad
. Trying to make the best of a bad situation though (the blade now seems kinda' thin there now... what with the grind below and the divot above), so I'm working on a handle shape that might minimize the thinned look... might even try to do something with a brass bolster to help the thinned appearance. Decisions decisions
. (I see what you guys mean about saying enough is enough and walking away from the grinder!!!)
I still need to do something to add "thumb grip" at that spot since my jinks didn't work out... I have an idea I'd like to run by you all. Has anyone ever tried making "invisible jinks" using a drill bit? This is kind of hard to explain, but I'll do my best... By "invisible" I mean that the jinks wouldn't affect the profile appearance of the blade because they would be drilled down into the centerline of the blade at that thumb point. The jinks themselves would be created via the spaces between the drilled holes. Using a fairly small bit, I'd drill into the thumb area to just a 1/16 or so... just enough to give some texture for the thumb to grip. They'd really be more like drilled "dents" than actual holes. I'd try to lay out a bit of a pattern for the "holes/drilled impressions", not to over do it, but just enough to provide grip. Thoughts? Ideas?
