Okay, I've been Googling a bit. Still don't know exactly what I'm looking for. Here's one option I found that suggests, for $9 + S/H, I can upgrade to a 200 lumen LED. But I wonder if I'm getting a quality assembly/bulb. And I wonder if it would eat batteries.
http://www.dealextreme.com/details.dx/sku.11621
The Surefire brand upgrade is quite a lot more expensive.
http://www.amazon.com/P60L-SureFire-G2Z-LED-80-lumen/dp/B001EJPEFW
Found this one... I assume I want single mode?
http://www.lumaforce.com/r2.html
Josh,, gotta check on those shirts after while,
Yeah, but that last lumnaforce link says 300 lumens for $20.![]()
Okay, so the Malkoffs are better quality and you get decent run-time? Am searching candlepower now for Malkoff threads...
Okay, I have a legit question for the flashlight elite. I actually do own a brand-name light, but it's an oldie Surefire 6Z incandescent. I have read elsewhere that a Cree R2 assembly will transform my light into a brighter LED. So... questions:
Are there multiple kinds of Cree R2 assemblies? Or just one?
If there are different output ratings, how do I know what will work with my light and its two CR123 batteries?
This is the Malkoff Devices P60 style dropin with solid brass heatsink construction. This design utilizes a Cree 8 degree optic. The optic has a very nice balance between throw and spill. It is an outstanding room lighter and short to medium spotter. It was designed specifically for use in SureFire 6P, 6Z, C2, M2 and G2 flashlights. It may or may not fit other models. The input voltage is 3.8 - 9 volts. Below 3.8 volts it will drop out of regulation and run direct drive. The output is 235+ lumens. The current draw is only 750ma at 6 volts. The runtime is 1 1/2+ hours on 2 CR123 primary batteries. It will easily illuminate objects at 350+ feet and will blind opponents within a 100 foot radius. The LED is a Cree XRE 7090.
WARNING: This light is capable of causing eye damage at close range. Please use the light responsibly!!!
