- Jun 6, 2013
I can't buy the Crow on the head thing.
When I would go to the casinos in a.c. It was told : if a seagal (bird) pooped on you it was good luck, you should go do some gambling. I always found it to be the opposite.
Are they basically weapons then?
They can be.
The Hartsfield style traditional grind is also a very efficient cutter/slicer. Ones like the Lum that are more Americanized, not so much.
I'd be willing to bet that both of those PH pieces are lasers. The gray one looks like it's double zero ground (from here) and the natural wrap looks like a RH chisel zero. Pretty slicy stuff.
What I mean is, are they designed to be primarily weapons? Or are they also designed for utility? I'm not asking if they can be used for utility because any sharp piece of metal can be used to scrape or separate media if the need is sore enough.
Tough question.
The tanto is historically a blade shape associated with Japanese swords BUT the smaller utility knives that are paired with the sword (kogatana, kotanto, kozuka etc.) share the same blade shape. Obviously they were ground differently but the overall profile stays close to home.
Ok, fair enough. What about "american" tantos?
My opinion? I think they're useless. They're designed for piercing but I've read several tests that show the traditional tanto shape is better for penetration (giggity).
Some argue that having two flat edges can be good for some tasks, I don't find them to be particularly useful but as always, YMMV.
Somehow I've managed to accumulate a few of them:
CRKT M16 Big Dog:
Spyderco Lum FB:
Cold Steel:
Cold Steel GI Tanto:
Benchmade 760:
Kershaw Zing:
(And my newest, a Benchmade 912 Stryker)
Depending on the use, I like them. They sharpen up super easy and the tips are strong yet still have enough sharpened surface to puncture stuff. I find I can be a lot more precise doing pencil hold cuts with them as well for more detailed work.
My recommendation is to spend less time hating grinds you don't like the looks of, and spend more time enjoying the grinds that work best for you.![]()
I think the hate for them goes a little like this:
"I don't like the way they look, so they're stupid and useless, and you're stupid and useless for liking them."
In reality, knives are for cutting things.
Tantos cut things...because they are knives.
Get over it; there are real things to worry about.
I totally agree with this logic Stabman. :thumbup:
BTW, is the Canadian Tanto shaped like a beaver tail? Just curious as I've never seen one before...![]()
