We need to sharpen it properly so that it will be really sharp. That is why we want to verify edge retention, although by theroy it has good edge retention. It also resists sea water, acid and base. Check test in 20% HCL.Interesting. It seems sharp in the video but not unusually so. Is it cast or ground?
53 or higherAny idea of hardness?
How about ductility and toughness? Classically these are fairly low in amorphous materials.
Property | Metric | English |
Yield Strength | 1600 MPa | 232, 060 psi |
Tensile Strength | 1850 MPa | 268 ksi |
Young’s Modulus | 96 GPa | 13, 923 ksi |
Shear Modulus | 34.3 | 4, 975 ksi |
Flexural Strength | 2000 MPa | 290 ksi |
Flexural Modulus | 65 GPa | 9, 428 ksi |
Poisson’s Ratio | 0.36 | 0.36 |
Charpy Impact | 6.5 J/cm2 | 31 ft lb/in2 |
Fracture Toughness | 28 MPa. m1/2 | 25, 481 psi.in1/2 |
Fatigue Strength | 300 MPa | 43.5 ksi |
Impact Strength | 800J/m | 15 ft-lb/in |
Elasticity | 1.8 % | 1.8% |
Why not test ease of sharpening and what steel got sharpest?Recently I was able to acquire a used CATRA machine, so I heat treated just about every knife steel I had, made 57 knives with the help of knifemaker Shawn Houston, and tested them all to see which cut the longest. For a few of the steels I did multiple heat treatments to look at a couple variables and to see the effect of hardness. I also compared edge retention and toughness to see which steels have the best balance of properties. https://knifesteelnerds.com/2020/05/01/testing-the-edge-retention-of-48-knife-steels/
They all got very sharp.Why not test ease of sharpening and what steel got sharpest?
Which steel took the least amount of time to be sharpened to a 'very sharp' state?They all got very sharp.
You would think but honestly they all got very sharp very easily, It just goes to show what happens when you have everything at the same geometry, using the same angle and the same abrasive (cBN).Just a guess, but I would assume that the steels with a very fine grain and low carbides would be the easiest to sharpen.
I must admit that I am not familliar with this terms of steel carateristics. Probably because I'm from Croatia. We have only two stages- sharp and dull.
Retention is when my Grandma honed knife on porcelan plate (bottom) and sharpness is when Grandpa stroped razor on belt. Sharpness and edge retention lasted all his life![]()
Hello Dr. Thomas! Would be REX121 have the best properties if it were hardened to 58 Hrc than other steels that are also hardened and heat treated to 58 Hrc? Thank You!Recently I was able to acquire a used CATRA machine, so I heat treated just about every knife steel I had, made 57 knives with the help of knifemaker Shawn Houston, and tested them all to see which cut the longest. For a few of the steels I did multiple heat treatments to look at a couple variables and to see the effect of hardness. I also compared edge retention and toughness to see which steels have the best balance of properties. https://knifesteelnerds.com/2020/05/01/testing-the-edge-retention-of-48-knife-steels/
Rex 121 has a very high volume of carbide and those carbides are very hard. So if all tested steels were at 58 Rc it would still be at the top or amongst the top steels.Hello Dr. Thomas! Would be REX121 have the best properties if it were hardened to 58 Hrc than other steels that are also hardened and heat treated to 58 Hrc? Thank You!
It would have the highest edge retention but the lowest toughness. The same would be true at any hardness. Going softer increases toughness slower for high carbide steels.Hello Dr. Thomas! Would be REX121 have the best properties if it were hardened to 58 Hrc than other steels that are also hardened and heat treated to 58 Hrc? Thank You!
