Cliff Stamp
BANNED
- Oct 5, 1998
Frank Warren:
At times I wonder if some of the people doing the really aggressive over promotion and outright attacks at times realize the harm that they are doing and at other times wonder if in fact that are doing it intentionally to harm the reputation of the product. In any case, you will find such people for almost any knife you chose to discuss, you just ignore them.
Interesting results on the Recon Scout and SH, I can do far more than 36 chops into seasoned wood with my Battle Mistress without seeing significant dulling. Most of the chopping cycles I do are about 250 cuts at least, often 500+, and I don't sharpen the blade after each session. I usually do that after a few, or whenever I clean it.
From memory I can't think of many ways in which the two Cold Steel blades I have used (Trailmaster and Recon Scout) outperform the #7 Basic I have used let alone the Battle Mistress. All that comes to mind is that the tip on the CS steel knives is much thinner and thus the penetration would be better. The handle also makes it really easy to throw like a large dart, including unintentional throws.
In regards to edge retention, ease of sharpening, cutting ability, durability (blade and grip and sheath), sheath functionality and in fact just about all blade aspects the Busse knives easily have the advantage.
The current owner of the Basic (my brother) also used both Cold Steel blades for months and his opinion of their relative ability is similar to mine. He put the most damage on the Cold Steel blades and the Basic has stood up to similar and more stressful things much better. From accidental high impact work (nails and other inclusions) to just recreational work :
http://www.physics.mun.ca/~sstamp/images/basic_sink.jpg
You can't even see the edge damage on the blade it is that small, and most of the edge is at about 10 degrees, that is the large bevel you can see but there is a more obtuse micro bevel about 1 mm deep on top of it. The two CS blades showed more damage including chipping when used with lighter stress (lighter mallet and straight cuts) on softer material.
The handle has been rebuilt again if anyone is wondering why it is not green and white like it was in the last picture. By the way can someone tell me the length and width of a new Basic #7 blade.
-Cliff
<font face="Verdana, Arial" size="2">There are people out there doing Busse a GREAT disservice.</font>
-Cliff
