NeedleRemorse said:
This can easily be defined objectively and lead to a productive discussion.
A great slicer can't be a great chopper
Use one of Ray Kirk's bowies.
You point though that there are tradeoffs is perfectly valid, this doesn't mean the entire matter is subjective and simply opinion, and even if this was the case, it doesn't hold that the question should not be asked as was argued in the above.
bhyde said:
Why aren't you making knives?
I don't enjoy grinding metal nearly as much as I do actually using the knife. I have however done it in the past to make a point about geometry vs steel in regards to performance. I do a lot of mods, usually flat/convex and may pick up a wheel to do hollow grinds in the future. I am more interested than exploring performance though than actually selling knives, so if I ever did actually start making them it would be similar to how Alvin does it, but I don't see that as likely, there are lots of makers who can do what I want to see.
Bastid said:
So you are saying finish makes no difference.
No, I said the proclaimed superior finish of the Sebenza which people argue for its increased cost makes no functional difference in a working knife because any superior finish aspect will be erased trivially in use.
If I ever have surgery I hope that the doc uses a finely finished blade. I am going to heal quicker due to less tissue damage.
Assuming the user knows how to sharpen his knives, this isn't a significant benefit, and it isn't like the Sebenza can claim a superiority in NIB sharpness over Spyderco and other similar knives anyway.
In fact the ease of sharpening of the Sebenza is actually lower, not higher, on many jig and similar systems, compared to Spyderco's due to the difference in initial edge angle.
...the time spent becomes moot to the point that I am makeing
You specifically stated in the above that since it takes longer for the maker to raise the finish you can argue the price from that point alone. This I noted would lead to odd paths such as paying more money for a maker who is inefficient or who has low QC.
The finish on a handle can also have a maked effect on the use of a knife for a long period of time.
It isn't like Reeve's finish is actually superior in this or any of the other effects you noted to the knives it gets compared to. Reeve does have a few aspects which do influence performance such as the rounded spine which improves ergonomics and you could easily argue would increase cost, but it would be hard to press it to his price level and I would call that design rather than a finish issue, similar to square tang notches.
...an answer to a question such as this is prejudiced by the fact that the answer will be based on the experience.
And as I noted, if you want to take that stance then it becomes universal. Your defination makes every decision and statement prejudiced, even your actual statement itself.
Planterz said:
...yours being the only one I've ever heard
As soon as I asked about the edge grind someone noted immediately they had seen the same variance in edge thickness on a large Sebenza, other problems have been noted on the forums.
To actually argue the consistency is significantly higher you would want
to at least do a forum search and present a higher defect rate for knives like the 710, Paramilitary and Rat Trap in comparison.
And just because you beat the crap out of your knives doesn't mean everybody else does.
I carried the small Sebenza in my pocket for a few days, the handle was immediately scratched up. I used it to peel some potatoes, cut up some cardboard and used rope and the blade was filled with deep scratches.
I sharpened the blade adjusting the edge angle and the coarse SiC slurry which again increased the cosmetic damage to the blade. None of this I would call "beating the crap" out of the knife.
But after just a brief period of use the finish is much worse than on an inexpensive FRN knife, which is why as noted I think finish is irrelevant on a working knife.
-Cliff
