- Jan 24, 2012
If it ain't broken don't fix it
If that were the case Jerry would still be using A2!!
Actually, I would love to see Jerry go back to A2. Great steel
I agree wholeheartedly, I'd actually prefer it over SR-101 at this point .![]()
Jerry's A2 must have been better than the A2 I've used. I like it, but no way would I take it over SR101.
Well, for my tastes A2 beats SR-101 by a large margin in the grind ability department. This alone tips the scales in favor of A2 for me, but yes Jerry did indeed do a great job HT'ing the A2 he used.
Perhaps have another corroborate the results after he's concluded the testing?
Also, another point to consider is that 3V can be heat treated differently depending on what is desired, whereas SR-101 is pretty much locked in to only one HT>
(1) Jerry has no obligation to publicly share his test data. In a competitive business environment, few companies would share their data.Yes according to this they have done a lot of testing on 3v....... where are those results? [see (1) below]
And why do they need to test 3v again? The problem is when you already said sr-101 outperformed 3v, why would you have a different outcome this time? [see (2) below]
I certainly agree with you regarding this on some things, but usually not when product development is involved. INFI might not have been developed if Jerry thought A2, D2 & ATS-34 were good enough.If it ain't broken don't fix it
Well, I am sure this will come out. I am shipping out my 911 to JP today or monday.
Got it here safe and sound. I am going to devise a good series of test. I will incorporate mechanical means as to eliminate human error. I saw the Jerry response and think it makes sense.
Notice Jerry said 3V will be tested against SR-101 ..
A couple thoughts on this .
Grindability will still likely be painfully low no matter how 3V is Heat Treated. Higher Vanadium content steels such as 3V are really counterproductive here, for me this is a huge disadvantage vs. INFI or really any plain carbon steel. A survival/combat knife should be capable of being resharpened quickly in the field with less than ideal sharpening mediums.
Well jerry found his niche with INFI , basically created HIS OWN steel that no one else can replicate , and it has the attributes you look for in a tuff knife with low Matinence , sticking with A2 or switching to 3v would just put him in sync with most others offering that steel , having something unique that only comes from you is more desirable imo . INFI passes just about every test I have seen thrown at it , so I ask .. IMPROVE WHAT ?
In addition to the field sharpening issue, the difficulty of grinding vanadium steels increase production time and wear on equipment which drive up production costs. It seems to me that I read some posts from Mike Stewart during his shift from A2 to 3v and he was lamenting the excessive wear on his equipment. Infi is a dream to grind.
