- Jun 11, 2012
And that's because 3v were never made to be used on knives.
Neither was SR-101 if it really is just plain ole' 52100 w/ excellent heat treat, 52100 is designed for ball bearing applications.
Not excited about the language of using 5160..maybe 3v.
I just read about an old post from Jerry comparing the two steels (3V and INFI) I was wondering if, when they did the test, did they subject 3V to iNFI's heat treatment...could that be the main difference between the two?
I got all of that from reading the posts. I was just wondering it - during the testing - Busse subjected 3V to his heat treatment protocols? I'm not suggesting 3V is the best option, just curious.Really comparing 3V to INFI isnt fair as INFI was developed with a very certain use in mind that being one of the best all around knife steels ever. 3V wasn't even originally developed for use in knives also the best videos of 3V (the ones Nathan has done come to mind) show heat treats that are defiantly not industry standards. While industry standard heat treats will normally give a good knife they will seldom give a great one. That is what I think separates the great heat treaters such as Jerry Busse, Brad Stalsmith at Peters, and Phil Wilson to name a few is they are willing to go beyond the industry standards to adjust the heat treat protocols to give the knife more of the attributes they want in a knife.
Chances are that when they compared the two, Busse probably followed the recommended HT protocol for 3V, likely provided by CPM or Bos
Yes according to this they have done a lot of testing on 3v....... where are those results? And why do they need to test 3v again? The problem is when you already said sr-101 outperformed 3v, why would you have a different outcome this time?
Because heat treats evolve. Jerry may have finally found a HT he likes for 3V and is giving it a test. One thing to be sure of if they switch to 3V it was done with good reason but I sure hope they don't because I REALLY like SR101.
Notice Jerry said 3V will be tested against SR-101 ..
A couple thoughts on this .
Grindability will still likely be painfully low no matter how 3V is Heat Treated. Higher Vanadium content steels such as 3V are really counterproductive here, for me this is a huge disadvantage vs. INFI or really any plain carbon steel. A survival/combat knife should be capable of being resharpened quickly in the field with less than ideal sharpening mediums.
if it ain't broken don't fix it
