That would make sense to me. There are many materials in nature that have that characteristic of being harder in one direction than in another (Kyanite,mica, talc...) Its because of the different atomic bonds in the material. If you take for example Mica which is a thin layered rock that peels off in sheets. It is used as an insulator for many older electronics you may have seen (Blues old stereo equip comes to mind) and is also used for high heat windows, among many other things. Anywayz you can peel it apart in one direction with you fingernail because it has a week bond (Van de wahls) in that direction. If you try to pull it apart in another direction it would be practically impossible because of the stronger bond (covalent) in that direction. I dont see why steel in certain alloys and conditions could take on the same or similar structure.Thanks for the video, I haven't watched it before. I'm watching now. I've read before about crucible and damascus/wootz steel before, it's a fascinating subject.
On the other hand other people say that these kinds of tests aren't accurate because of the weird molecular structure of wootz steel. If you test a wootz steel sword with a file you're only going to find it has a hardness of like 40RC. But because of the way the molecules are aligned (or something, I don't understand the science behind it) the hardness of the blade over the length of 2 or 3 inches is much higher. So the strength of the segment of blade that you're slicing something with is much higher than what you'd expect by just testing 1mm of it with a file.
The first point I would call your attention to is the fact that only very few of the wounded, in modern wars, are wounded by cuts or stabs, so few, indeed, that to one who reads, in newspaper accounts of battles, of desperate charges with the bayonet, of fearful hand-to-hand fights at the taking of redoubts, and so forth, where the imagination pictures the wounded from bayonet stabs at hundreds or more, the real number must appear absurdly, even incredibly, small. In the late Russo-Turkish war, where I had the opportunity of seeing thousands of wounded men, I am sure I did not see more than half a dozen suffering from sword, or sabre, or lance, or bayonet wounds. And all the enquiries I could make did not enable me to come across any one whose experience differed much from my own.
The corpse was chiefly interesting to me as illustrating the frightful nature of the wound which the terrible jambiyah (Bedawi knife) will inflict. There was a gunshot in the head, and the body was much mutilated with sword-cuts; but the jambiyah wound would have been judged by any one not acquainted with the weapon to have been made with a broad axe. The thorax and abdomen were laid open from just below where the left collarbone joins the breastbone down to the left groin, and all the viscera interposed were severed as with a razor.
The Arabs are very expert in its use; they hold it point downwards with curve inward, and in attacking always aim at the supra-sternal notch at the base of the neck, a blow which, if rightly placed, splits open the whole chest wall and is instantly fatal
When Clot-Bey laid out a cadaver before his class and began opening it up, one fanatical student attacked him with his jambiya, slashing downward at his chest. According to his obituary in the Boston Medical and Surgical Journal:
The blade glanced upon the ribs. Clot-Bey felt that he was not seriously hurt. He drew a bandage from his case, and while adjusting it upon the wound, thus addressed the students: - "We were about to speak of the relations of the sternum and the ribs. I will now, however, explain to you why a blow from above, downward, is not likely to penetrate."
