Strong-Dog
- Mar 1, 2014
He has already stated that his English isn't great.
Jus Boy, if that is what you meant I apologize. I thought you may be referring to them making the steel with a better process
So they sharpen better as well?
S30-v is a pretty hard steel. If you are used to using "lower end" steels. So, if it is dull it will be hard to sharpen. Regardless of who makes it. Best thing to do with higher end steel is to touch them up occasionally. Whether you think they need it or not.
As some here have said, if you think s30-v is crap steel, you probably don't know how to sharpen. Or don't have the proper tools. Same with d-2. But, again, if your knife comes "dull" from the factory it is gonna take a little, maybe a lot of work to get it sharp. That goes for, as far as I'm concerned, any of the new "super steels".
Personally I like aus-8 and 8cr13mov. Cause they are easy to sharpen to a razors edge. Do they hold an edge as long as "high end" steels. Nope.
Strong Dog, do you do competition cutting or something? Honestly, I can't really tell too much difference with a lot of the high end steels other than that some take a lot longer to sharpen than others. At work, I have a knife in my hand for about 4 hours a day. Since I do so much cutting (I install commercial vinyl and linoleum), I mainly use a fixed Stanley knife with disposable utility and hook blades. Those don't hold an edge worth a darn, but even if I was using the best knife steel available, I guarantee I would spend more time sharpening than it would take to just slip a new blade in. I have to laugh.... I have several $1,000 invested in knives and I use a $10 disposable more than anything else. My work edc is usually a $20 Dozier (for when I don't have my tool pouch on). After work, I rotate a few of my higher end knives bust most of them are for fondling and admiring, and in that case, steel type doesn't matter one bit.
The steels I like are great.
The steels you like are junk.
Huh. I guess I got a lemon.Ok, its a bit more than an hour later. Sorry to keep you waiting. [img=http://s6.postimg.org/u63vvlrd9/IMG_20140504_211133.jpg]
Nope, no rust. I was kinda hoping for some patina action. No cigar.
Mainly just the cheapo plastic ones. Teflon is ok I guess, but I try to avoid anything that isn't metal, mainly because plastic seems to gunk up easier and develop blade play over time. Although, I have not used any al mar knives so I cannot speak to their quality and longevity.Are you including teflon washers? I used to think they were synonymous with cheap, but I have a few knives with them... Al Mar Shrike comes to mind.... One of the smoothest opening knives I own.
http://www.bladeforums.com/forums/showthread.php/995132-Pros-amp-Cons-of-teflon-washers-GO!
Some can get by with an SAK because they just don't use their knives all that much while others need a much more wear resistant steel because their knives seen a lot more use.
So, before super steels, no one used their knife frequently? Why can't you just sharpen it when it gets dull?
I'm always interested to see the alloys some folks consider to be substandard for creating cutting edges. 420HC is often attacked as are 440C, D2, and most recently, S30V and Elmax. So here's a simple question. Are there any knives you would refuse to purchase based on their blade alloy alone? If so, which alloys are on your hit list and why?
It all depends on price. I'm not laying out $150 for a knife with 420J2 without knowing a LOT about the maker and their reasons. If you showed me a Griptillian in 1055 with a good heat treatment, I'd be all over it.
Since you asked, I don't think I would ever buy a knife that uses 420HC. I only have one experience with it.... my Leatherman Juice, which is actually part of my edc. I will buy another Juice when this one dies, but the blade on it is terrible IMHO. It has ruined 420HC for me. Why waste my time on that steel when i can get another Dozier folding hunter with Aus8 for $20? I always carry at least a small folder in addition to the Juice for cutting anyway. Also, I avoid any Chinese knife marked with '440'.
