I've watched an instructor snap one in half barehand.
So the instructor grasped the bare blade with his left hand, the handle with his right and simply snapped it like it was a stick? Man, I would like to see that.
I've watched an instructor snap one in half barehanded. Failure to radius the transition to the tang is poor design, as doing so would cost very little more and make the knife much stronger. Many people have been fine with the classic KABAR. It's still poorly designed, though.
Your analogy particularly falls apart because I've made no claims about what the blade should be able to do. I've just agreed with the obvious weak point that was mentioned above and reiterated that it was a design flaw, a particularly egregious one that's been known for many years.
I thought that bigghoss's analogy was perfect. The "design flaw" survived a war, and the knife was praised by its users. It has limitations, yes. But "egregious" points at a major problem that caused frequent failures. This was simply not the case.
FYI, the Government specification for this knife has included a 1/32" radius at the junction of the tang/blade for more than 50 years. So things aren't as egregious as you might suppose they are.
Yes it will break, but it shouldn't that easily. I was using another piece of oak firewood about 3" on diameter and 16" long to baton the knife. After the KABAR broke (on the second hit), I switched over to a cheap machete and proceeded to baton it and split the rest of the evening's firewood. As I said earlier, I'll be carrying my BK7 next time.
A hatchet would get you kindling, small stuff, and usable sizes of firewood faster and easier and with less risk to expensive cutlery.
^^ This^^ For a Ka-Bar profile fighting utility one. Emergency Batoning when it needs to be done and your options are low."Knife, Fighting Utility"
...I was using another piece of oak firewood about 3" on diameter and 16" long to baton the knife. ....
Pi R Squared?
I always thought pie are round!
I spent my whole life looking for a square root, they're all round too!
