jeffsenpai
- Feb 24, 2010
Are you serious? $50 and $25 for those knives? Was it a show only special? Those look great at that price point.
Hi guys,
I received my new Kizer 4412 two days ago from Extream Addiction. I haven't cut anything but paper and string, but I have been carrying it and opening/closing the knife to get a feel for it.
Lets start with the good:
WOW! The knife is beautiful! It is a full titanium frame lock with titanium pocket clip. There is a steel lock bar insert with over travel protection. It has a ceramic ball detent. The blade has a nice stonewash. I love the fuller combined with the harpoon swedge up top. The edge came reasonably sharp and glides through paper with little effort. The detent is strong in the closed position, without play. The action is pretty smooth and it locks up solid, with no blade play. I also like the nice polished screws and standoffs. I have not taken the knife apart, so I cannot speak to weather the screws are secured with locktight, or if they are soft. A few people here on BF have mentioned they had trouble with the screws when repositioning the pocket clip. This model is single position(tip down/right hand), so I won't have to test that. I am ok with tip down on a thumb stud opening knife. If it were a flipper, I would prefer tip-up.
Now for the not so good:
I have only had this knife for 2 days and the thumb studs are already coming loose. On this model the thumb studs act as the stop pin in the open position. This has occurred just from opening and closing the knife. I have not done any heavy cutting. I have not "spine wacked" the knife(I can't see a reason to do that to any knife IMO). They are so loose from 2 days of opening/closing that they will rattle if I shake the knife in the closed position. When I received the knife the lockup was around 30%. It's now around 50%. I assume this is in part do to the loosening of the thumb studs, as now the lock bar has to move over more to take up the slack in the studs.
The second issue I have noticed is when the blade is partially open, there is movement in the pivot/handle scale interaction. If I hold the blade and handle with separate hands (while partially open), then push/pull, I can see and feel the pivot moving slightly back and forth in the scale. It's as if the hole cut in the handle scale is slightly too large for the pivot. This doesn't occur while the knife is locked open. There is no blade play currently while locked open. It is also not apparent when closed as the detent is securing the blade.
I'm not sure what to do. I really like this knife and feel it's a tremendous value for the price. These issues don't really affect the cutting performance of the blade and lockup is solid for now. My concern is the loosening thumb studs and pivot play developed rather quickly(2 days from new out of box). I bough this directly from Extream Addiction and the knife looks brand new, so I don't think it is a used knife that someone before me abused. This knife appeared perfect when it arrived, and still looks like new. I'm worried that if the thumb studs continue to loosen, or even come unattached, then I will have a non-functioning knife(remember that on this model the studs act as stop pins in the open position). I don't want to give up on this knife, as I really do like the design and materials. I will try contacting Kizer and see if a repair is possible...
Hi, flash900:
We DO NOT ask the dealer to do the repair work for us, it is simply an exchange.
1) You return the knife to the dealer, dealer exchange a knife to you,
2) dealer sends knife back to kizer, kizer send a new knife to dealer.
You as a customer do not have to wait while the knife is under inspection and repair. The dealer is not involved in the repair work at all.
Thanks.
Kizer
Received my Kizer KI3404A1 from ExtremAddiction today. This is a great little flipper at a great price of just under $120 delivered! Looking forward to KI3404A3 with plain titanium handles.
It flips real nicely and I added a bit of oil and it's getting smoother. The handle has a nice gritty texture. It weighs just 3.1 ounces. Most importantly, the blade length is indeed 3 inches long and 0.12 inches thick. It comes extremely sharp. No blade play and well centered. The jimping is just right.
I believe you are referring to the post by member "phxgadgets" on 3/6/14 where his clip snapped. If you read it again carefully, phxgadgets does state that the clip snagged when he was getting in the car and broke. Your comment is making it sounds as if the clip spontaneously snapped in half by itself and that is not what happened.
Kizer.
Kizer.
I respectfully disagree. I have bent various pocket clips on numerous occasions in my bench vise to test the flexibility and/or toughness of the clip. Sometimes, just to tighten or loosen the clip in my pocket. NO breakage occurred with my folders.
The pocket-clip design, by its very nature, WILL SNAG on things. Therefore, clips that recognize this potential are manufactured with a tougher steel-type or proper hardness which will permit the clip to BEND rather than BREAK under adverse circumstances.
I suspect that you would concur.
