Patrice,
I hope that you will not mind me posting a final thought.
I think that this was/is a great thread. Patrice was one of the very first people to welcome me to the Forums. As such, he knows that from the very beginning I've wanted a TW-90. However, I can't "really" afford one at this moment. I am sure that I'm not the only new guy who "wants it all".
So everyone is talking about spending about $3,000 or so to get a 2x72 grinder that will hold up forever ideally also flip to horizontal has 1 1/2 tooling arms a good tool rest and doesn't break the bank. Most other makers also have or want a 9" Disc sander and a Mill or even a good HT oven, at least I do.
Here's what I came up with.
Willmont LB-1000 grinder.
- uses steel 1 1/2 tooling arms
- can be flipped easily for horizontal grinding with their plates or you could build your own from plywood.
- uses a Direct mount motor- no belt
Cost is $1,500 with VFD add 288 for fully adjustable work rest.
Rod Neilson magnetic 9" disk grinding hub (awesome) $375.00 with a flat and a beveled disc.
eBay for the 9" disc motor, I found one for $188 but let's say $200.00
These two can share the same VFD, Silver_pilate did a WIP on it this, very easy and saves us $300 plus dollars.
And finally you could get a Mini Mill from the Little Machine Shop for $820 or an EvenHeat Oven for $1,000
That brings the total to $3,182 with a mill or $3,363 with the HT Oven.
Of course you could spend less on the 9" or the mill but I like nice stuff so that's how I'm gonna do it.
I will still get a TW-90 one day, but I'll learn a ton between now and then
Thanks
-Eric
