Okay, when I last checked in the blade was pretty much done and the guard and handle material epoxied on.
Which led to some shaping:
I will say this about the Bakelite - doing the initial grinding where lots of material is being removed quickly with a coarse belt is far from fragrant. But when it comes to fine-tuning the shape of the handle on a finer belt, I quite like the way this stuff grinds. Less material is removed at a given grit / belt speed as compared to wood, so it was easy to go slow and get just the right shape.
I'm pretty happy with the way the handle turned out in terms of feel. It's pretty much right where I want it.
While I have a hard time calling this piece "finished" - as I keep seeing things I'd like to touch up - it's close enough for pic or two. So say hello to Old Yeller.
The sheath doesn't go with this particular knife - it's just there as a prop. But this knife will get its own Paul Long treatment. You can see a bit more of the texture in the wrought iron guard up close:
Etching the guard after it was already on the knife was a bit of a challenge, but Dan had the idea that some carefully applied clear nail polish would keep the acid from etching either the blade or the Bakelite. Which was a good idea, except for my less than completely careful application of said nail polish to one side of the blade resulting a brightly etched line on the ricasso which gave me fits to rub out
resulting in one of those areas that could use a bit more attention.
Anyway, overall, I am pleased with the knife and happy to have been included in the project. It was a lot of fun and I learned a lot. And came out of it with not one, but two knives (as told elsewhere, the backup blade made it to completion against some staggering odds):
Roger
