Thanks a lot will come back to this lost and tell you for sureWhen you've got your stones let me know and I'll link a bunch of videos that can help.
Also got a question considering getting ruixin system from gearbest how are the stones? Are they any good or if I buy it would I have to buy new stones right away?
Robert,
I often use a toothy edge, i.e. 2000-3000 grit finish in the harder steels like S90V, MAXAMET, K390 ETC.
But that toothy edge is past razor blade sharp. And I do agree that the toothy finish is better suited to cardboard and etc.
Robert,
People seem to use the term "working edge" in one of two ways.
Either an edge that is perfectly adequate for the job at hand, such as box cutting, rope cutting, yard work, what have you. No extra bells or whistles. Often with a more obtuse, robust bevel.
Or, the edge left behind after a highly refined edge has been used and is no longer capable of feats such as hair whittling, or keen razor sharpness, but still continues to get the job done on more mundane tasks for a good long time.
Those are the contexts I usually find the term popping up in most often.
I would venture that most folks don't equate a 2000-3000 grit finish as "toothy", generally speaking. So, that's another area where there is no standard definition.
Generally, with the higher carbide steels, it seems like the range generally referred to as toothy is somewhere in the 320 to 600 (or 800) area.
Sorta like one man's ceiling is another man's floor.
Toothy, to me, means that it "feels" toothy when I run my thumb along the edge.
I need to get to at least 5,000 to not feel it.![]()
Hey hello sorry for bothering you again just wanted to make sure I'm not getting the wrong stone was gonna order like right now but noticed there where two ultrasharp diamond stones one is 300/1200 which is 20 dallors more than the 400/1000 one and the 300/1200 one has much better reviews than the 400/1000 I'm confused aren't they the same stone and there made by the same company why is one much more expensive than the other? Sorry if this sounds stupid don't want to make a mistake, and I would rather get the cheaper one of course and also I was gonna get a Norton IB8 100/300 can you use it with water or oil only? ThanksWell, now I know where to send my knives when I get frustrated.![]()
Allright thanks for clearing my mind will order today, thanks againAlex, either one will serve you well. It's not going to make a huge difference. The 300 is slightly more aggressive, the 1200 slightly more fine. Companies make products in a variety of grits.
The IB8 is an oil stone, and I'd recommend using it with oil. It will make cleanup and maintenance of the stone easier. You don't need a lot, just a thin amount smeared with a finger on the surface to keep the removed steel from clogging the pores. Then you can wipe it off with a paper towel afterward. Easy peasy. Mineral oil, (pharmaceutical mineral oil sold as a laxative preferred), works and is cheaper than the Norton Oil which is also mineral oil but may be slightly lighter in weight. Either way, the oil will last a long time.
