- Oct 30, 2005
I'm sorry, but logically, part B does not follow from part A. What you have there is called a non sequitur. Your conclusion does not depend upon the conditions you assert in the earlier portion.
If you want to debate the term stupid in terms of substantive information, well isn't that what Broos has been doing all along? Noting with factual information the unreliability of effects?
I don't know.
Has Broos attempted to duplicate the "tests"? Are the "tests" non-repeatable? Simply because some exacting measurements of forces, angles, etc. were not specified does not make the results invalid.
If my Trailmaster sucks at chopping pine with the factory edge, does that mean we should assume that no other Trailmasters will suck at chopping pine, since no test of at least 5 (a common minimum sample) has not been performed.
If one were to write down exacting criteria for each phase of the "tests" NOSS4 performs and do the tests to these criteria, would the results be any different? I don't think they would, since the tests are taking the knives to the extreme. Making that assumption of not being valid would be a "non sequitur", yes? Would it not be better to say that further tests should be run but based on these observed occurances the results appear to be as stated by NOSS4?
If Broos wishes to prove the tests "stupid", then his "scientific" results would be different, perhaps the opposite of those of NOSS4. Until that time, is there any proof of "stupidity"?
But that is assuming Broos would choose similar or like tests. Since Broos appears to be under the belief that the "tests" of NOSS4 are "stupid", I'm sure the "testing" Broos would perform would be different.
BTW - nothing against Broos personally. But, if a person wishes to put some knives through "H-E-double hockey sticks" and that person doesn't follow some ideal criteria, that is not sufficient reason to negate the results and call them "stupid". The name calling is borish.:thumbdn:
Afterall, people don't jump on the sharpening "gurus" for their sharpening results, do they? Are these results repeatable? Have they been done with a proper sampling? What is the point of hair whittling (beyound being "cool")? Does a knife that can whittle hair cut cardboard longer?
