What CPM-steeled have you "used"??And just where do you think I got the idea that grinding worsened the edge holding of some of them? I tested them before and after: For a majority of them nothing happened, but for some of them something probably did. I usually don't buy CPM knives (and I never had any re-ground thinner), but the few I had were all pristine factory edges and were all screwed from the box. It could be the structure of CPM just soaks up and retains heat better, but probably the higher abrasion resistance also plays a role...
I base my geometry choice on exactly what Randall offers in edge thickness, 0.020" at the shoulders: According to you a stock Randall Model 12 with a hand-applied 30 degree inclusive edge is a sashimi knife? So be it...: It showed no issues in over 1000 chops...
The S30V knife I tested that failed was never re-ground thinner, only the edge was sharpened by hand on a diamond hone...: It kept its 0.040" edge base...: That's a "sashimi" knife to you?: It could hardly slice a tomato...
The Gerber Mark II in S30V micro-folded severely while slicing thin cardboard, this with a stock edge that had a slight strengthening micro-bevel added by hand... Yeah, I'd say the factory grinding has been hard on it...
Gaston
S30v and CPM-154. Not steels that should be used for chopping.What CPM-steeled have you "used"??
Nice job outing yourself as being the culprit of your failing edges.
Your grinding and honing skills obviously need more time and patience.
That makes sense.S30v and CPM-154. Not steels that should be used for chopping.
To not try a 3v chopper and condemn all CPM steels with only experience from commonly folder steels boggles the mind.That makes sense.
I had a feeling that he confused cpm-154 with 154cm.
I should have left the bit of poetic illustration out of it. That is not a sashimi edge. Point conceded. It also isn't an edge that can reasonably be expected to hold up to the stresses created by a 10 inch blade impacting a hardwood knot without damage. Perhaps you have a unicorn or perhaps you've gotten lucky so far. Perhaps you just just feel the need to try to convince people that your personal favorite knife is superior in all ways to anything that's existed before or since and your tests haven't been particularly fair or objective. We weren't watching you do them.
How about a $2000 RJ Martin Raven (tested and then re-sharpened by hand for over a year, hoping to gradually get down into better steel, before finally giving up), or a $700 custom by Martin Knives in CPM-154? With the $300 limited edition Gerber, that adds up to about $3000 in CPM steel. Just how much am I supposed to invest in this stuff, seeing it instantly fold, at thick angles, on cardboard or Maple wood, before calling it quits?
Whatever the cause, sometimes the emperor just has no clothes
Sure some 440 was just as bad, or even worse (but so far never Al Mar's Aus-6), but at least you get the sense 440, D-2, and even some carbons, can occasionally get in the vicinity of OK... CPMs so far were for me an amazing step back compared to everything I had previously seen. Whatever the cause, sometimes the emperor just has no clothes.
Gaston
Okay, well remember when you said this:How about a $2000 RJ Martin Raven (tested and then re-sharpened by hand for over a year, hoping to gradually get down into better steel, before finally giving up), or a $700 custom by Martin Knives in CPM-154? With the $300 limited edition Gerber, that adds up to about $3000 in CPM steel. Just how much am I supposed to invest in this stuff, seeing it instantly fold, at thick angles, on cardboard or Maple wood, before calling it quits?
It is not the steels fault you used a knife for something it was not intended. And amount spent does not equal what you wanted those knives to do for you. You can get a better knife in 3v from many makers for a lot less that will do what you want, you are choosing not to do so. Again, not CPM's fault. That is on you.A steel type having "characteristics"? What about the characteristics of the grinding? The grinding comes mostly last, and can ruin the edge holding in an instant... Why not talk about grind "characteristics" instead? You don't talk about it because you have no means to verify exactly what happened in the grinding of any particular knife, which, even on the cheapest knives, is a long series of uncontrolled hand actions, so you stick to steel types because that makes you feel like you have control over what you are getting...
You contradict yourself sentence to sentence. "some 440 was just as bad or worse" to "CPMs so far were for me an amazing step back compared to everything I had previously seen". Well which one is it. Can't be both. And again, you were using traditionally folding knife steels as choppers, and a gerberSure some 440 was just as bad, or even worse (but so far never Al Mar's Aus-6), but at least you get the sense 440, D-2, and even some carbons, can occasionally get in the vicinity of OK... CPMs so far were for me an amazing step back compared to everything I had previously seen. Whatever the cause, sometimes the emperor just has no clothes.
Beyond CPM steels being terrible, both to sharpen and to hold an edge (probably because they are so hard to grind, so whatever "characteristics" they have is shot to hell by the grinding), and Carbon steels being really easy to sharpen, and having acceptable, but second rate edge holding, I never observed much "characteristics" by "steel type". I tend to go case by case. An individual knife makes it or it doesn't.
Gaston
KOD, if that poor guy had to drink all that Natty to make his ax, no wonder he looks pissed. LOL
