- Aug 21, 2013
So, Gaston, you don't like CPM steels and you feel that carbon steel is second rate. Tell me, just what steel do you like?
Rostafrei
I bought mine from BladeHQReally surprised bout the Katana complaints. Don't hear that too often.
I have one and the only complaint I have is the spinning pivot is a pain in the ass to mess with.
Otherwise, mine is a great example. Ordered it from Japan. Maybe that has something to do with it??
Joe
Don't they use 440B?Randull 440C
Condemning all CPM steels with experience from only two of them, and not the one that would hold up to your intended tasks the best (3v) is a ridiculous notion. New or inexperienced members should completely ignore these thoughts.Beyond CPM steels being terrible, both to sharpen and to hold an edge (probably because they are so hard to grind, so whatever "characteristics" they have is shot to hell by the grinding), and Carbon steels being really easy to sharpen, and having acceptable, but second rate edge holding, I never observed much "characteristics" by "steel type". I tend to go case by case. An individual knife makes it or it doesn't.
Then, you contradict yourself proving why your evidence is bunk.A steel type having "characteristics"? What about the characteristics of the grinding? The grinding comes mostly last, and can ruin the edge holding in an instant... Why not talk about grind "characteristics" instead? You don't talk about it because you have no means to verify exactly what happened in the grinding of any particular knife, which, even on the cheapest knives, is a long series of uncontrolled hand actions, so you stick to steel types because that makes you feel like you have control over what you are getting...
Anything with a saber grind that was less than 70% of the blade.
Seriously...just get an ax already.
That'll work as well. Seems like more of the exception though. And don't get me started on scandi blades. I'm clearly not a fan of those.Actually David Boye has had a very successful and long career as a custom maker and now small manufacturer. His main folder has a saber grind that's about 50% of the blade width at the midpoint. The key lies in using thin stock to begin with and a 0.01" hand ground edge. Kind of like the Scandinavians do with smaller blades![]()
Gaston
Sooo... Does this mean that all the times you've had a knife blade reground to an edge geometry befitting a sashimi knife, treated it like a felling axe and then posted on the forums how much X highly respected hard use steel failed and sucks, that you've been there to watch the regrind process before you expounded your unconventional wisdom or does grinding not have an effect on steel properties when it's done at your behest?
