Lets say a customer wants a Bowie; 5 1/2 inche Blade Length, 1 1/2 inches wide, Hollow Grind, with a deep Clip and a Swedge. Now you can grab a piece of steel and head to the bandsaw, but after this you may just want to fire up PS.
Open up a new canvas, Control + N. Name: BOWIE, Make it 7 Wide by 3 Height, 72 pixels/inch, RGB Color, White Background...OK.
Click and Drag on the corner of you New File Window and bring it up against your Palettes on the left of your screen.
BTW, these are the Palettes I like to see when Im working.
From Top to Bottom; NAVIGATOR, SWATCHES, HISTORY, LAYERS/PATHS.
Lets go to the Navigator Palette. With the Slider under the thumbnail, move it to the right and fill your window with the Canvas.
Next drop down to the Layers Palette and make a New Layer (Create New Layer icon)
If your Rulers arent showing Press Control + R.
To make our layout easier, from the View Menu > Show > GRID.
On your keyboard Press
P to bring up your Pen Tool...you should have the one with the little
x next to it.
Move your Cursor on the canvas to 1 Across and 1 3/4 Down and Click to leave the first point (The Point of your Bowie).
Next click at 3 1/2 Across and 1 Down (The back point of the Clip).
Click again ae 6 1/2 Across and 1 Down (The Upper corner of your blade).
Still at 6 1/2 Across move down and Click at 1 1/2 Down.
Move to your left at 1 1/2 Down and Click at 3 1/2Across and 1 1/2 Down. (For the BELLY of the Blade).
One more Click on the Point again to finish the Work Path.
Your shape should look like this.
Phil, now we know why you play with Photoshop and dont make knives.
Its just a Basic Shape, were going to move everything.
Lets start by making the Belly of the Bowie.
With the CONVERT Tool from the Pens Toolbox. Click and Drag to the LEFT from the point we set for the BELLY of the blade).
Now Click and Drag from the POINT of the Blade straight to the RIGHT.
The HANDLE that starts coming out in front of the blade...Click and Drag it Back to the Point
Your Bowie should look something like this.
Now we can start moving things with the WHITE Arrow.
I moved the Point of the Blade up a bit, the Clip back a bit and the Bottom Corner up a bit and came up with a shape like this:
If you make something you like, but want to keep on designing...Just go to your Paths Palette...Click and Drag the Path to the CREATE NEW PATH icon Next To the Trash Can. Your Original Path is Saved and you can continue to work with your New Path.
If you want to show your Customer a Line Drawing of your designs:
In the LAYERS Palette
Make sure a New Layer is activated...Not the Background Layer
In the PATHS Palette make sure the right Path is Selected...Click on LOAD PATH AS SELECTION Icon (third circle from left).
Edit menu > STROKE.
You could save this Line Drawing as a .GIF, 2 Colors and E-mail it to him...
Or you could wait and show him something more impressive
Me, I would wait.
We will be using this file in the next lesson so lets make sure we Save it....Control + S.
