Question: is the stop pin touching the blade tang when opened, or is it just the thumb lugs
I've looked at it from all angles, using a flashlight to look for light peekin thru, and as far as I can tell the blade is secured by both the thumb lugs and that pin.
A friend said his only contacts with the thumb lugs. Has me curious now
Just bought a working finish ti-scale for my xm-18 3.5" fullered spear
Hopefully it looks as cool in my mind as it will on tuesday. I searched and searched, but haven't found anyone using similar setup
Just the regular stonewashed finish. I got the smooth, working finish ti scale cominWell now you got me curious. Working finish scale with what blade finish? I’m sure it’ll look awesome.
I don't have any others to compare, but I'm enjoying mine. The fuller is nice, you can flick open like with spydercos(spydie flick)Not seeing many discussions on the fuller spear xm-18 3.5". How is it compared to the regular spearpoint? Wondering If this should be my next hinderer.
No mods needed. If I try to flick the blade open straight up, its a bit tough, but flicking it parallel to the ground or even angled up a bit, it flies open.Can you really flick your fullered spear open with a finger flick like a spydie? I can't even use the thimbstud to open mine. I guess I would work down the detent and build a ramp but I prefer the flipper tab anyways. But back to topic, does your middle finger flick open? and did you do any modifications to make it work?
Can you really flick your fullered spear open with a finger flick like a spydie? I can't even use the thumbstud to open mine.
