Regarding an overhead mount. OK, now picture standing in a room with about an 11 foot ceiling with your hammer and build some type of steel arch or beam up beside or behind your hammer and stick the motor on top of it approximately 10 feet in the air (7 feet for hammer height and 3 feet for belt length). It would look more like some kind of monument to the motor gods than a motor mount! Something in the roof rafters looks OK, because all that you see is a belt coming down from the roof rafters. Fellas, I stood at the feet of the motor god monument, and I was in awe of the power of the mighty motor god, but I didn't like it as a hammer mount. Come on guys, we can figure something out!
Mike, I measured the flatness of the belt pulley with a set of calipers - completely flat for all I could tell.
I will measure the little motor pulley, but it is very small - as small as they could make it I believe. Mike, thanks for the explanation of the calculations for beats per minute. That is some real information that anyone who reads our little chat can use forever.
Bruce, I was looking at pictures of every hammer I could find on the internet last night. Some (all?) Little Giants had the motor hung off the side up top. I need to find a picture of a larger LG to look at. Somehow they stopped the wobble.
Mike, I am not quite getting your concern about the idler setup and the belt contact surface, but it seems like an important point. How should the idler be applying pressure to the belt to increase the contact with the drive pulley rather than decrease it? Just because a hammer can function with a messed up setup doesn't mean it is functioning as well as it was designed to do. The guy who sold my hammer to me said it was in good working order, but it had one pin broken completely into, all of the pin holes were worn out and way oversized, etc, etc. A hammer hitting is not necessarily a hammer hitting well.
I need your comments/criticism about this design before I take it any further. Oh, I almost forgot. Mike, my motor's pulley is 3 and 1/4 inches in diameter.
Hey Fellas. Mike, what would be the best part of my drive system to change in diameter to get to the correct bpm?
I was going to ask about blocking the frame hole. Working off to the side, is there really many times when you use the hole through the frame? I have 2 tapped 1/2 inch holes in the frame just below the frame hole, and there is a flat spot on the frame there, and that is why I was mounting exactly there.
I haven't yet decided on exactly how to tie the hammer to the floor. The hammer will be elevated on a platform that I have built that is about 5 and 1/2 inches high. I figured I would hammer drill the floor and place some bolts, but it was mentioned earlier basically trying to place nuts in the floor, so the machine can be slid rather than lifted over them. Seems like a great idea but will be a little trickier to do.
Mike, why do you say you would mount the motor on a stand below the jackshaft rather than on the hammer?
I will try to make a drawing of the mounting setup I am thinking about and scan it or something. Would be easier to discuss then.
The way my idler pulley was mounted before, it had to have a really long range of motion to lift the ball weight up to around vertical, so the pedal wasn't really hard to push, I guess. Therefore, the belt was really long to accommodate the long idler pulley travel. When you stepped on the pedal, the pulley lifted and lifted taking up a bunch of slack, until the weight got close to vertical where the weight lightened the tension for holding your foot on the pedal. All of that belt slack needs to be eliminated, so I need to change that setup.
