- Nov 2, 2009
Here is a picture of Mike's hammer that he emailed to me. It shows the ram/plunger guide adjustment on the front.
[/IMG]
Bruce, it is interesting that Freund put that info in the other book and not in the book title that I have. I think quite a bit of the United/Fairbanks info from the brochure in Freund's book that I have is identical to the Barbour-Stockwell material. I think Barbour-Stockwell just took much of the same brochure and substituted the name Dupont for Fairbanks. One of these days I will compare them directly.
Mike, thanks for the further explanation. I think I understand now. I agree that hanging the pulley off the back should not change alignment, although it may in fact help against wear of the bushings, since hanging the drive pulley off the back may help balance what must now be front-heavy loading with the crank/flywheel out in front of the yokes and the drive pulley inside the two yokes . However, you raised an interesting point about your sleeve. Does your sleeve over the shaft rotate with the shaft? Is it actually connected to the shaft with those set screws? If it does rotate, what does it rub against on each yoke? Is there a groove machined in each yoke? That is something else I would have to add.
Mike, you certainly must be right about the thick sleeve acting essentially as a large spacer to maintain the shaft position. (You have determined that it is 11/16" thick walls?) It would seem that the drive pulley and the crank/flywheel being screwed to the shaft on opposite ends of the yokes would accomplish that spacing, but the sleeve must be further insurance. I am learning more with each communication.
The alternative to moving the drive pulley out to the rear is to simply leave it inside the yokes and mount the motor on the side either low or high. At this point, I do not believe that a hammer could be well-balanced with the weight of the motor and all of the support table and brackets mounted up high on the side. That must be the reason the previous owners of mine welded a brace to a wall to operate it. Therefore, the motor would have to be mounted low down on the side, with a jack shaft mounted up high on the side. That would require 2 belts and two lesser mounting brackets on the side. Since most of the weight would be in the motor and its mount down low, the hammer could probably operate that way. I do not have the option of mounting a motor in the rafters like Bruce and some others have done.
I need to make a list of the requirements to move the drive pulley to outside the rear yoke. 1) New shaft long enough to mount the pulley and place a gib key in the end and machined for a gib key and a larger key for the drive pulley 2) Gib key made and shaft machined to accept it 3) Spacer/sleeve with 11/16" thick walls machined to fit precisely between yokes and tapped for set screws to contact the shaft and tapped for grease fittings on the ends where sleeve may contact yokes 4) Bushing made for the drive pulley to make up for the difference in shaft thickness on the smaller end versus thicker part of shaft 5) Machine flat the "doughnut" casting on the rear outside part of the rear yoke 6) Fabricate motor mount 7) Turn drive pulley around backwards? 8) Fabricate new treadle linkage.
What am I leaving out?
I compared the information in the Barbour Stockwell Company "Dupont Power Hammers" brochure to the information in Freund's book, "A Blacksmith's and Hammerman's Emporium." The material in Freund's book is a reprint of the United Hammer Company "Fairbanks Hammers" brochure from June 15, 1917. The short answer is that if you have the Barbour Stockwell brochure on their Dupont hammers, you have everything and actually more than the material in Freund's book. The Barbour Stockwell brochure is not dated.
Nearly all of the material is identical, with some very small differences and a couple of helpful additions. The Barbour Stockwell brochure is obviously a minimally rewritten copy of the United Hammer Company brochure with "Dupont" substituted over and over for "Fairbanks." The biggest difference and best portion of the Barbour Stockwell brochure is page 10. There are 4 adjustments (stroke, spring, treadle and brake) discussed that are very good information and which are not included in the earlier United Hammer Company brochure about the Fairbanks hammers. On page 8 of the Barbour Stockwell brochure, a specific recommendation is given for locating the hammer under a line shaft, and the belt adjustment is discussed. Again, neither of these was contained in the earlier United Hammer Company brochure on the Fairbanks hammers.
Interestingly, Barbour Stockwell added a line on page 2 stating "Working Parts Guarded." It seems that Dupont hammers must have come from the factory with guards of some type. Additionally, on page 3, they state "The Bronze taper gib provided for taking up wear in ram guides makes possible a very accurate ram adjustment and insures a perfectly true square blow at all times." This line was not in the earlier Fairbanks brochure. At some point in time, this modification was made and did not exist on the earlier Fairbanks hammers, as evidenced by the fact that my earlier Fairbanks does not have this modification.
I just noticed another difference in the material as it pertains to the adjustable guide. Barbour Stockwell slightly altered the drawings of the machines to put the adjustable guide in their pictures. They neglected to alter the picture on page 6 of the machine with the tire-welding attachment, but all of the others are altered. The exploded drawing/parts illustration appears to have an altered face plate, but it does not appear that they offer the parts for the adjustable guide. It seems they altered the face plate in the drawing but forgot to list the parts.
We know from the fact that Mike's and Bruce's machines have the adjustable guide and are co-branded with Fairbanks and United tags that United must have created the adjustable guide during their ownership of the line of hammers between 1917 and sometime during the Great Depression when United sold to Barbour Stockwell. The adjustable guide must not have existed in 1917, because the drawings in the 1917 United brochure clearly do not show any adjustable guide. All Dupont hammers apparently have the adjustable guide.
I just did an internet search for Dupont hammers. I found a picture of a restored 1894 Dupont hammer. It is on a site under "Rough and Tumble Engineers Historical Association." The anvil and frame are a one-piece casting, like a little giant. The drive pulley, crank/flywheel, idler pulley and face plate are definitely the predecessors to the later Fairbanks hammer parts. This shows that Dupont not only "participated" in the manufacture of the hammers, as Freund stated, but Dupont actually made a hammer under their name at least as far back as 1894. This is the hammer line/technology that they eventually sold to Fairbanks in 1902.
Barbour Stcokwell just revived the Dupont hammer name during the Great Depression when they bought the line from United and changed the name from Fairbanks back to Dupont. My earlier statement that all Dupont hammers must have had adjustable guides is true only for the second generation of Dupont hammers.
