- Aug 21, 2014
I guess I just dont want to conjure anything....Need you ask? The obvious answer is absolutely!
cool idear but curious.......are these hacksaw blades full m2? reason I ask is I've been on a factory tour back in the 90s where they made Sawzall metal blades. which were 2 rolls/ strips of different steels welded/ bonded together. one strip was m2, other strip was a cheap steel. I asked why they did that and it came down to good enough and lower cost as the answer. curious if the hacksaw blades are made the same way? thanks.....
It will cut card board ALL DAY....... Me personally, it's the best edge holding I've seen. (but I don't have any delta 3v)I'll give her a good going over. I'm not going to cut nails into or anything like that, but I'll cut up some cardboard and slice up a stick of firewood out of our woodpile. Then I'll sharpen her up in my Wicked Edge and see how she sharpens.
Last night I ground some more on the give away knife from the steel you sent meCrag the Brewer . You can still see some scratches from the coarser belt. The amount of time I spent grinding this one knife is equal to the total time I spent grinding all four small AEB-L blades. Therefore I can assure you (
jbmonkey ) that my opinion is firmly in the camp that these saw blades are a) M2 through and through, and b) a nightmare to grind.
Also,Crag the Brewer you see how the blade looks like it has an ever so slight recurve... turns out you can indeed burn the steel if you grind it thin enough. Just where there would be a sharpening choil, the steel heated up suddenly and changed to blue almost in an instant due to a slightly too slow pass on the 220 grit belt. So I gave it a flex test, and the edge there chipped right off. A very small section of it, which was easy enough to repair into the slightly recurved profile you see above, and subsequent flex testing there yielded no further damage. So yes, it is a high speed steel, but it will burn if that fact is taken for granted, which I stopped doing after that experience.
thanks for info. look awesome....I expect to hear great things besides whats already been said.....Most are bi-metal blades for cost reasons, like you said. (only the area where the teeth are HSS)
even those are still capable of making Good knives as the rest of the blade is usually still hardenable, but not just of the same capabilities.
These aren't like that. These scream Cut Me!!!
I'm super curious of Your opinion, because I know what kind of knives you own....![]()
Crag the Brewer said:These aren't like that. These scream Cut Me!!!
Robert do you have calipers to measure thickness behind the edge? I think it will be useful to know the difference between the two whenever you do your testing.
