- Oct 2, 1998
Some people are probably getting lost here. So let me help using some info I have found.
Simple physics then takes over that anyone can understand. Make something too hard and it will break or chip. Make something to soft and it will bend.
Bring a 54 spine to a 62 edge and guess what you get when you chop or stress the edge. Flip a coin to see what you get in the case of a Mad Dog knife.
Best Regards,
Mike Turber
BladeForums Site Owner and Administrator
Do it! Do it right! Do it right NOW!
CLICK ON THE LINK BELOW RIGHT NOW! YOU WILL BE GLAD YOU DID!
www.bladeforums.com/ubb/Forum8/HTML/001202.html
- Iron is a useful knife material, but it tends to lack hardness, as a result we can turn it into steel.
- Steel is made by adding elements such as carbon, silicon, molybdenum, chromium, etc. to iron. These materials do not mix in a homogeneous form and they form quite complex structures. To complicate matter the heating and cooling of the metals causes the alloying elements to form different structures in the iron. Most of these structures tend to have phases that are primarily one type of material, such as ferrous carbide, which has a higher melting temperature. When a single material forms in a region is tends to form a single grain of metal.
- When heated past 1700F for a few hours, the steel is still solid, but the microstructure normalizes into Austenite (Allen Blade's favorite word), and the alloying elements tend to distribute themselves evenly. After this the structure will take different forms, depending mainly upon how quickly it is cooled. At low cooling rates the iron, carbon and other elements tend to separate out at different rates.
- As a result a slow cooling rate (such as air cooling) will lead to pearlite. This material has ridges of ferrite and cementite tightly combined to form a pattern like gray mother of Pearl.
- A slower cooling rate will result in pearlite with larger features. The slowest cooling rates (especially annealing) tend to lead to large grains of ferrite. Under a microscope ferrite looks shiny and white.
- A faster cooling rate will lead to a fairly tight combination of elements called Martensite.
- If you can manage to cool the material very fast you will also have some retained Austenite. This tends to form as sharp spears shaped grains.
- The microstructure of a metal can be determined by polishing the surface to make it flat, and then using an etchant to make the surface more visible. A microscope is then used to observe the structure. Careful observation can determine the structure of the metal. You can also use Isothermal transformation graphs (found in materials handbooks) to theoretically estimate what microstructures are present in a material.
- The hardness of a material can be measured using a hard stylus that is pushed into the surface of the work. Hardness is a function of how deep the stylus penetrates the surface (the Rockwell C scale).
Best Regards,
Mike Turber
