Just realized I never posted a photo of the finished product! (One of them is going to be for me, which I haven't had the time to finish)A couple of custom utility hunter's in Magnacut, rough ground and ready for heat treatment.
This is my first time working with it, and so far it's really nice to work with, easy to drill, easy to grind.
Can't wait to see how it works after HT!
Why do you need to anneal? Are you planning on doing some reprofiling or other machining work? If you are trying to reharden it to get to a higher HRC then just reharden it skipping any other steps since it's likely already in an optimal condition.Hey all,
I've got a couple pieces of hardened Magnacut that I would like to anneal and re-heat treat, what is the best way to go about doing that? Can I simply do the anneal and that's it? if so, what temp, soak time and cooling rate would be best? Or should there be some sort of normalization before annealing?
It might be better to start an all new thread, but thought it a fitting question to be asked here.
The existing heat treat should be fine, but I'd like to anneal them so I can stamp my makers mark in them and maybe do some fill work, and once that's done I will probably tweak the heat treat a little from what they have now.Why do you need to anneal? Are you planning on doing some reprofiling or other machining work? If you are trying to reharden it to get to a higher HRC then just reharden it skipping any other steps since it's likely already in an optimal condition.
You shouldn't need to do any normalizing or grain refinement steps if it had already been through that. Unless you are doing something like forging or overheating, etc.
Maybe let us know what you are planning on doing and we can help further
From Larrin's site on thermocycling steel. It doesn't appear that you will have to do anything other than anneal for your stamp, file work, etc then reharden and temper.The existing heat treat should be fine, but I'd like to anneal them so I can stamp my makers mark in them and maybe do some fill work, and once that's done I will probably tweak the heat treat a little from what they have now.
Though I would like to try forging Magnacut at some point, so it would be nice to know what to do for that as well!
Thanks for that! I thought I remembered that article only applying to low alloy steels, but I reread it and found the part talking about high alloy steels.From Larrin's site on thermocycling steel. It doesn't appear that you will have to do anything other than anneal for your stamp, file work, etc then reharden and temper.
How to Thermal Cycle Knife Steel - Knife Steel Nerds
Experiments and recommendations on how to process steel after forging. Hardness, toughness, microstructure. Some controversial conclusions!knifesteelnerds.com
Now if you do any forging you can back up further down the charts and do some normalizing and grain refinement but with the extra elements in magnacut I don't think it is as important. Shouldn't hurt anything though
I'm not sure I'd deviate that far from the data sheet. Larrin has done a lot of research on this steel and I think his numbers are better than anything else.Thanks for that! I thought I remembered that article only applying to low alloy steels, but I reread it and found the part talking about high alloy steels.
I was looking around some more and found D DevinT recommend with Magnacut doing a soak at 1375F for 8 hours, should I go with that? I guess if anyone’s gonna know what to do it’s him!
Thank you so much for you help/time!!
That would be a subcritical anneal, you could also do a full cycle anneal if you want to. I recommend you double foil wrap the blades as Magnacut is prone to decarb, even at lower temperatures.Thanks for that! I thought I remembered that article only applying to low alloy steels, but I reread it and found the part talking about high alloy steels.
