- Aug 11, 2012
Autoshop paper towel? Seems much stiffer than the paper towel im using.
looks very sharp![]()
Hey also does it with wet paper towels in another video!
Whatever- you guys have it covered without my input.
BTW when you sharpen knives there is always loss of blade height (edge to spine.) How do you think knife blades wear out?
I'm quite sure I understand sharpening. I have been doing it for 45 years.
While I'm not questioning your ability to sharpen - and I in fact have quite a bit of respect for you for having sharpened for far longer than I've been alive - I am questioning your understanding of the current tools available to polish and/or sharpen a knife.
Prior to your mentioning of ruby bench stones, I hadn't even thought of them as an option. Now that you have mentioned them, I'm curious to compare them to the stones that are much more commonly used by waterstone sharpeners. The base material (carborundum or ruby) should be chemically pretty much the same thing, and from my brief investigation, both synthetic waterstones and ruby stones use sintered ceramics (e.g. aluminum oxide) but the binder is likely much different between the two.
I went and looked em up , the only ones that I could find with a "grit" rating were rated from 80-325 "grit" no rating standard given.... So coarse on any given scale..
And they are too soft for powdered steels anyways. Even if you could get them fine enough they wouldn't be able to cut the carbides in many modern steels. On the coarse side this isn't a huge issue.....
I wish I could afford all the nice stones and strops some of you guys have .I have to resort to the old no money trick a piece of denim a scrap of 2x4 and mothers mag polish I easily get mirrored edges in just a few strokes . I saw it on a Rockstead knives video and it Shure works wonders on my knives .
There is more than one type of carbide in powder steels depending on the mix and its only when the heat treat is really good that standard stones start to have troubles. I've sharpened S30V with a Norton India stone and I've had some S30V that was hardly scratched by my best waterstone and could only be done on diamonds.
Another thing that I'm curious about but will need to do some testing - if the stone is physically hard enough, couldn't a bit of pressure fracture the carbide and result in some "sharpening" even if it isn't as high on the Moh's scale? I realize it wouldn't polish it and would be relatively uncontrolled, but could certainly have a positive effect anyway. Would like to pick up some etchant and see what is really going on under the microscope.
That would come down to the Friability of the carbides in the steel , for this to work you would probably at a guess need pressures beyond what we can produce while sharpening. And I would hazard a guess to say that the pressure needed would exceed the surrounding matrixs' ability to hold onto the carbide. Purely speculation on my part. Again I cant claim to be metallurgist.
What type of scope do you have?
