- May 7, 2004
Are you going to chamfer the edges of the handle like we see on a factory 560? I think that will make it look nicer and will probably save your pockets too.
WilltheBarb said:Are you going to chamfer the edges of the handle like we see on a factory 560?
chickentrax said:Psychopomp, do you do anodizing??? I have three Aluminum forgings that require anodizing...
ZZJake said:Rich, if you have a stationary belt sander, rig a platen table to grind those bevels.
Didn't I read somewhere that the four dot 110's were originally beveled by hand? Perhaps it's just a matter of developing the skill through practice.chickentrax said:I'm not sure what you're referring to, but I haven't figured out a way to grind/sand/cut *all* the edges [finger grooves, too] without getting an uneven bevel. I'm looking into using a router mounted upside-down in a router table with a 45* [or 60* if I can find one] cutter or grindstone chucked in the router. Small enough dia to fit inside the finger grooves (which my belt sander won't do).
I have a countersink which will bevel the holes.
I'm not in any hurry.![]()
chickentrax said:My SS SHCS's came today. I spent some time shortening them to fit flush and the shoulder to support the rockerbar/blade. Worked out quite well. I included a spare screw in the scan to illustrate how the threads don't touch the pivot areas [coff *Preston* coff]...
Rich,chickentrax said:Mike & ZZJake - Thanks for your suggestions! I can remove stock with a variety of tools...but not uniformly, and not easily...
The best idea so far is to use a ball-bearing router bit with 45* cutter, mounted in such a way that I can pass the scale under the cutter and have it shave off .030"...
Grainger's has such a cutter...
If I flip the cutter over on it's shaft, I think it'll work...but I'd wear two heavy jackets, leather gloves, glasses & a face shield, and maybe a helmet...![]()
Funny, I have a 1/8" round router bit that uses a bearing. I thought all round over bits worked with them.chickentrax said:Preston - The heads of the screws are recessed .050"; I can't go too much further because the Ti is only .160" thick...I don't mind screw heads sticking up...![]()
Mike - I'd need to use a cutter that will work with the ball-bearing shaft. It's the bearing that keeps the cutter at a fixed distance from the work. A rounded or even indented-square corner would be OK...
Since it's only about .030" that I'll be taking off, I think it will work...The problem is holding on to it...![]()
geothorn said:Have Mr. Houser or Mr. Buck approached you, to purchase the design...?![]()
I think that if it were going to come to that, as moderators of this forum, they could've stopped you on your first post.chickentrax said:Do you mean have their lawyers served me with papers charging patent infringement, copyright violations, and fraud???![]()
No, not yet.![]()
