Looks good. Excellent job!
Some suggestions:
1) Use some sandpaper or a diamond file and round off that sharp tip at the ricasso just a tad to make it less sharp.
2) I thought I lapped the scales flat on the disc sander, but they may have warped a bit afterwards due to internal stress. Doing figue-8 sanding with 120 grit paper on a flat surface like Richard suggested is good if the scales are not flat. Another cause may have been not completely snugging the Corby bolts down. I use a pair of small fat handle screwdrivers to snug then down tight. Tighten in this order - front, rear, middle, repeat until snug. If the front or back has a little gap, loosen the middle bolt and tighten the gap end bolt more.
Another cause can be getting epoxy in the hole of the female bolt. It will refuse to tighten down tight.
A trick to make gaps and glue lines less a visual issue is to dye the epoxy to match the wood color. I prefer the colored powder type epoxy dyes. A kit with brown, tan, black, red, and white can be blended to create a close match for most woods. Another thing people do is use a vulcanized liner material to create a contrast line between the tang and scales. This takes care of gaps quite well. Red and black are the most common liner colors and the epoxy can be dyed to mar0th the liner for a perfect transition.
3) Your handle is what is called a "Broom Stick" style. Not a terrible thing, just lacking "flow".
Shaping the handle adds a lot to the look and feel. I make the front a little narrower than the butt and put a tiny waist to the handle. I don't like a full Coke-bottle handle except on big fighter style knives. Look in the gallery and online at a bunch of knife handles and see what they usually look like. You can still modify the handle now or wait until later when you have a belt sander. Tape the blade up heavily when doing that to avoid scratching the blade or cutting yourself. I would slightly round over the transition from the front to the sides, so it is not such a sudden drop. Then I would taper the bottom side so the cross-section is slightly egg shaped
4) Looks like the plunge lines are not quite even. Again, this isn't ruinous, just not as ascetically pleasing. A file guide is a great tool for getting them perfect. Most all knife suppliers sell one.
