New Cruwear PM2?
The fit and finish on mine is the worst I’ve seen from Spyderco. There’s some type of glue on the scales I noticed when flipping the clip to tip-up carry. The action is not good, either. I tried loosening up the stand-off next to the pivot but the screw is stuck in the standoff so it just spins and loosens the other screw. With all the glue that came on the clip, there isn’t any blue loctite on the pivot or standoff screw I could get loose.
This is all stuff I can fix with a few torx wrenches and some sandpaper or a dremel. It should be a decent knife once I spend an hour or two cleaning it up and tightening down the screws properly with some blue loctite.
The G10 scales are definitely smooth, as described. It’s a nice feel, even a bit smoother than some aftermarket aluminum scales I have on other PM2’s. The blade is nice and sharp. It’s got the most pronounced grind lines on the side of any Spyderco blade I’ve seen. Just running my fingernail across it, I can feel and hear the grind lines. It’s a true satin finish on the blade, either way.
Edit - came with some sticky stuff on the blade, which is also off center. I thought it was grease at first... it’s greasy. Tried rubbing alcohol, then warm water. Got most of it off. The grind lines on the side of the blade trap a lot of oil / debris. I’m used to wiping a blade off on my jeans or shirt but this texture requires a few alcohol swabs to get everything off. Not easy to keep clean.
I put blue loctite on the stop pin screws and pivot screws. I can’t get the action halfway decent without a lot of blade play. I’ll try disassembling it and adding some lube.
Spent a few minutes trying to scrape the glue off the scale where the clip came from the factory. It’s less shiny but will have to hit it with sandpaper or something and then try to blend it in with the rest of the scale.
So, this isn’t the best PM2 I have. It’s not bad, just nowhere near the quality of my S110V, M4, even the S30V versions I have. After an hour of cleaning and oiling / adjusting it’s ok. The blade centering is still off and the grind lines on the blade will take some getting used to. I’d recommend picking one up from a brick and mortar store so you can check this stuff out but then it’s a KC exclusive. I’m not sure if Cruwear is just inherently hard to work with and the rough grind cannot be avoided... maybe it’s an aesthetic choice. Maybe mine is a one-off. It’s an interesting knife for sure.
Got mine at lunch too and love it. Something different. I don't have any of the above issues. My blade is centered, slightly stiff as with most of my other PM2s, and the satin finish and smooth G10 are really lovely.
Just opened mine and I’m impressed. I must have gotten a good one because my blade is centered and the action is free-dropping smooth, which is nice. The scales are definitely different, and the lock is pretty strong, but overall this is a great knife!
Love the screws, Anyone have any idea where I can find some bronze ones, or different color torx screws for spydercos?
Ok back on topic,,I have the same problem with the glue on the side where the clip was but its nothing some goo gone wont fix.
*unpopular opinion alert* I like the smooth g10 for a change over grippy g10 because of how easily it slips into the pocket, same reason I carry the smooth CF cruwear manix over my other CF manix thats peel ply. but thats just me.
Blade is centered perfectly but I have noticed a bit of lock stick when flicking it open with force, but none when opening with the thumb. Ill add some oil and see if it changes anything.
One thing Ive learned from Spyderco is to never judge the action from the first unboxing. Like a good pair of dress shoes, they have to break in before they get comfortable, but that doesn't mean they're lesser quality.
Just got mine. Just to echo others.
- blade grind lines as so nice.
- action perfect.
- centered
- perfect sharpened even bevels
I'm not 100 sold on smooth g10 yet. I'll carry it before make judgement.
Video and pictures below(sorry for portrait video video)
As a leftie I switch every pocket clip on every knife. I know the "glue" or whatever it is he's talking about. It was caked under the clip of my s110v pm2. It seems to flaking off little by little with pocket wear.
Got mine as well, no complaints. Will look it over a bit closer tomorrow but action is good.
Got mine today, I like the smooth G-10. Feels 'soft' in the hand. Centering on mine is pretty good, maybe 60/40 if not dead on. Happy with this one + it's CruWear!
The fit and finish is same as my recent M4s. No decernable issues. Blade is centered and smoother out of box
Might send mine back... The blade isn't centered and won't drop free, even with a flick of the wrist the blade doesn't move from the open position.
Disappointing.
Mine came a bit tight. But well centered. A few drops of oil and using it since Monday have loosened it up. I haven’t touched the pivot.
I suggest contacting KC for an exchange if you’re not happy. The sooner the better while they still have some in stock to exchange for. Otherwise you may be looking at a credit, and miss out on this fantastic exclusive run
Disappointing.
Action is probably the easiest thing to fix on these. Just loosenpivot screws. Adjusting that might even center the blade. Youd be surprised how just tiny bit of turning in the pivot affects the action.
Blade centering and pivot tightness can also be affected by clip position and tightness. One thing I have noticed is both of my locks are sticky.
anyone else having severe lock stick? Thought frog lube would fix it but its gotten worse. I tell myself its fine but then I pick up my 51200 and my m4 and the locks have no stick at all and it kinda bugs me.
tried the graphite fix, little to no change.
Any advice?
Reading these posts...it seems fit/action/function is hit or miss with this run. I own/owned several variations of the PM2 and never had any real issues.
