- Jan 14, 2000
Just did a little internet research.
Found this post from a few years back on the Spyderco forum from Michael Janich of Spyderco (bolded text added by me):
DLC (Diamond-Like Carbon) is molecularly bonded to the surface of the material and will not "chip off if hit hard enough." It also does in fact increase corrosion resistance.
For a more technical explanation of the process used to apply it and the benefits of the coating itself, I went to IonBond, the folks who developed it. This is from their web site:
PACVD Technology
PACVD (Plasma Assisted Chemical Vapor Deposition) is a vacuum based process used to deposit DLC (Diamond Like Carbon) coatings, also known as ADLC (Amorphous Diamond-Like Carbon). All educts of the PACVD process are gaseous. This makes it suitable for coating 3D components uniformly, without the need for rotation as is necessary in PVD.
The coatings are amorphous in structure and contain around 70% sp3 bondings, which accounts for the high hardness of the coating (10-40 GPa).
The PACVD process is used for coating a very broad range of conductive and non-conductive substrate materials at temperatures below 200° C. The typical thickness is in the range of 2 – 3 µm.
DLC coatings feature excellent hardness, wear and low friction properties under dry or deficient lubrication conditions. They are ideally suited for tribological systems found in engines, machines and other mechanical assemblies with sliding and rolling movements. The perfect surface finish without any post-treatment makes them ideal for high precision injection molding tools as well as for decorative purposes. DLC is chemically inert and biocompatible which allows for its application on medical components and implants.
Broad range of substrate materials
No distortion of high precision substrates
No post treatment necessary
Gaseous process for uniform coating of 3D geometries without rotation
Green technology with respect to educts, process and products
Here's a link to additional information that substantiates its qualities of hardness, adherence, and corrosion resistance:
http://www.renishaw.com/advancedmaterials/en/diamond-like-carbon-coatings--14211
In my previous job, many of the knives we produced were DLC coated--including DLC-coated A2 tool-steel blades. I saw many of these that had seen extensive hard use in tactical environments. The DLC held up extremely well. Even when the exposed steel at the edges of blades was allowed to corrode, the corrosion did not "bubble" under the DLC like conventional coating or plating processes and stopped where the DLC started.
I hope this helps.
Stay safe,
Mike
PACVD Technology
I hope this helps.
Stay safe,
Mike
