Good point.If it comes down to a choice between a cracked blade (or one that's all stressed out and full of micro fractures),... or losing 1-2 points of hardness, which would you chose?
Also, does anyone have a line on where to get either the Parks or the Houghton?
Maxim oil for Parks 50
5 gallon pail
http://www.knifeseek.com/forum/showthread.php?t=54969
Houghton k
for an alternative
http://www.qtstools.com/TechInfo/K.pdf
I've had repeatable luck with 1095 in 130deg canola, which is inexpensive, reasonably stable, available, low-smoke, high flash-point, and food safe.
-Daizee
5 gallon pail
Houghton k
for an alternative
Ive read on another forum that another new quench oil is out that is every bit the equal of parks..Maxim DT-48, in the side by side test results I saw it was equal or a tad better...I also know people who are consistantly getting 66rc on 1/8" 1095 from mcmaster carr quench.
Parks #50 is way too fast for O-1. O-1 has a hardening time of 27 seconds. As i have found out, you can air harden O-1 to an extent9Hard enough to resist filing and cheaper drill bits). Parks AAA is perfect for O-1, but is too slow for shallow hardening steels.OK, let me ask here since this thread is current. What if I want the best results (fullest hardness without blowing it apart) from quenching O1, but might one day want to use the same oil for W2, 1095 etc? Is a fast oil too fast for O1?
count, you blow my mind.. !! where do you come up with this stuff?? do you have everything under the sun bookmarked or what?? super navigator !!! deluxe![]()
The only results I have seen from mcmaster carr quench oil in the 66rc range on 1095 was from a double quench. The single quench was not producing full hardness?
To answer that, Yes. In "Real" metallurgical testing, it DOES matter. Can you wash your face with steel wool? Yes, but there are products made for the job. I believe if you are striving to make the best possible product, you should use the best possible products for the job.
I use a knife everyday, in fact i carry two. The point i am trying to make is if you are out in the field and a blade you are using is quenched in canola or whatever other inexpensive oil, and it bends, or folds an edge because it is not hard enough...is it still a useful tool? I would rather send my stuff out with the best possible heat treat available to avoid any concerns. Will a blade quenched in canola at 57-58rc cut as good as a blade quenched in parks at say 60rc? Yes...for a little while. Why not go the extra distance to insure that you optimize the heat treat for the steel? Let's face it, people use knives for a lot of uses they are not designed for...but a knife is designed for cutting, I say optimize the most useful aspect of a knife...the edge."Real world" and "Real world metallurgical testing" (whatever that is) are two very different things. "Real world" is when you take a knife to the field, hold the knife in your hand and use it as a tool to make your life easier. To someone who actually uses tools, nothing else matters.
The point is: if the user can't distinguish between the two, does it really matter? It matters to a scientist in a lab. (period)
