- Jan 18, 2015
I just saw the Yo2 in stock at a place. Don't know if I can say it though
I'm pretty sure he was just mentioning that as an example...
And the stock went quick of the base S30V models.
To sum the discussion up, nobody actually knows why M390 has not become a mainstream steel.
Too bad: nothing wrong with having H1-like corrosion resistance+S30V-like hardness in one blade.
A. That wasn't at all the question you asked in the OP. B. You've been given a number of answers, the primary ones being cost vs need. C. Look into the Vanax and Nitrobe 77 and ask the same questions. There are many reasons not to use a steel despite the fact that it may have desirable properties.
A. ?
B.
Here
http://www.bladeforums.com/forums/s...-no-m390-steel-models?p=14460557#post14460557
C. Certainly, many bizarre steels. I am however asking about a steel that Spyderco *has* used
for a short period of time.
There have been several answers.
I.
M390 is less corrosion resistant than H1...
-Maybe. But in my own tests with salt water, H1 developed stain spots similar to M390
http://www.bladeforums.com/forums/showthread.php/1261716-Picturs-of-my-steels-rusting-test-H1-m390-ZDP-189-N690Co-CTS-XHP
M390 is rather impressive in that test.
Unlike ZDP-189 and XHP, which Spyderco markets as stainless.
II.
Supply restrictions of M390 vs. S30V or VG-10.
-This is just a steel. There is no fundamental limitations with any of its components.
If there is demand, the manufacturer would certainly find a way to supply the due quantities.
III.
Cost of M390 stock vs. S30V or VG-10.
-The costs of these steels are tens of $ per pound, in the ball park of $40/pound reading
knife makers posts. Steel price is not a big factor in Spyderco knife price.
IV.
Time spend grinding (And therefore more cost) M390 vs. S30V or VG-10.
-That was my own suggestion, and it is pure fantasy. Grinding may cost just $0.2 more, I don't know.
V.
And I'm sure the differences in the heat treating are also a factor.
-Maybe, but I guess if a company is in a knife business, HT should be the last reason to worry?
Unless there is a real, unusual issue with HT and M390 steel. If so, here could be the answer!
I will throw this out. Why does Spyderco still use Bohler Elmax then? There are lots of other options for the Lion spy but they continue using this?
This actually perfectly reinforces our supply chain talk. The Lionspy is a collaboration with LionSteel, manufactured by LionSteel in their Italian factory. So it's actually not surprising that the Italians use Bohler's Elmax as they are next door to Austria.
The opposite argument is also true.
if Spyderco already has Lionspy to provide ELMAX, they need no extra efforts to source M390.
possibly. however, the way I see it (and of course, I'm just using my consumer knowledge to make a guess), is that LionSteel using Bohler to make Lionspys at LionSteel in Italy is actually quite different than Spyderco using Bohler to make other knives in Golden. In the event that something were to happen in the manufacturing process, LionSteel and Bohler could rapidly turn around a solution with minimal costs incurred. However, if something were to happen in the manufacturing process while out in Golden, there would be significant lead times and additional costs incurred Spyderco and/or Bohler. so unless Spyderco starts outsourcing more work to LionSteel, it's unlikely that there'd be an advantage to using more m390 over more cts 204p.
Just take a look at what's happening right now on the west coast with the port workers' strike. the longer your supply chain, the more chances that something could go wrong, and the more significant the cost to rectify the situation.
A company tries and a company abandons. The company knows, but we are all just guessing.
I am glad that you did, becausr I had a strong desire to reply to that postI should probably have my head examined before (or after) sticking it into this rabbit hole, but...
I am always listening to what Benchmaniac 707 would say (evfen I like Ares much more than 707).Company B has had a more complicated history with M390 than many here probably realize. They sold some knives with M390 blades for a while, then stopped. There was a lot of speculation about why, and rumors about quality control problems and very poor yield ratios. After a period of time (I don't remember how long - might have been a year or so), they started selling M390 blades again, and by and large people are happy. However, there is a current thread in the manufacturer's forum describing one knowledgeable customer's dissatisfaction with an M390 blade and the company's follow-up.
