- Mar 11, 2011
The work I did, consisted of removing the NRV, (non return valve, we call a check valve) replacing the pip with viton, from the original cork pip, add new lead washer on the NRV and reinstall, change all the gasket/seals, from the fuel cap, to the reserve cap, to replacing the lead gasket where the burner mounts to the fount, to new burner seals, above and below the spirit cup, (old were asbestos, and leaked fuel), and replacing the leather cup seal on the pump. I also purchased a new windscreen for it, as this model didn't have one. The brass one I purchased, is next to a black one from my Optimus 111B. The black one fit my 45, but the brass one had a wider edge/lip/roll:
I placed the one from the 111B over the new brass one, and traced a general guide line:
I had purchased a Dremel like tool, and chose a grinding stone:
Started grinding for a bit, and the flame ring, in this case from my 111B, just started fitting in it:
A little more grinding, and she fit like a glove:
Soft brass clogged up the grinding stone some:
But anywhos, it turned out great:
